Charging issue for the DJI Air 3 Battery Charging Hub
12Next >
3671 56 2023-9-27
Necronomic
Flight distance : 225535 ft
Sweden
Hi!
I've recently got an pretty large powerbank with 50000 mAh both with 100W and 30W output.
When I'm trying to charge the batteries through 100W port to the battery hub, the hub goes to accumulating mode instead.
Is it not possible to use 100W powerbank with DJI Air 3 Battery Charging Hub or is it something faulty with my powerbank? Anywone else with 100W powerbank out there?
Other scenarios:
30W directly to the hub works fine, just abit slow.
100W direclty to the Air 3 works fine too, but max 65W.
The powerbank I'm currently using is this one:
https://sandberg.world/en-gb/product/powerbank-usb-c-pd-130w-50000
Thanks in advance!
2023-9-27
DJI Paladin
Flight distance : 318 ft
Hi there. We do apologize for the trouble. The DJI Air 3 Battery Charging Hub does support the Power Bank function. Please insert the Intelligent Flighty Battery into the charging hub. Connect an external device via the USB-C port, such as a mobile phone or RC. Press the function button and the status LED of the charging hub will turn solid green. The battery with the lowest power level will be discharged first, followed by the remaining batteries to be discharged sequentially.
To stop accumulating power, press and hold the function button until the status LED turns yellow.  After stopping power accumulation, press the function button to check the power level of the batteries.
The Power Accumulation function will stop in the following states:
1) The battery with the highest remaining battery level is fully charged, or the battery level of batteries that transmit power to the battery with the highest remaining battery level is lower than 5%.
Note: Power transmission stops when the battery level of all the batteries that transmit power to the battery with the highest remaining battery level is lower than 5%.
2) The batteries with the relatively high remaining power are fully charged.
3) Insert or remove any of the batteries.
4) Press and hold the function button on the battery charging hub.
5) A device is connected to the charging hub via the USB port.
2023-9-27
Necronomic
Sweden
DJI Paladin Posted at 9-27 17:39
Hello there!
I think you missunderstood my question...?
I want to charge Air 3 batteries FROM my powerbanks 100W usb-c output TO Air 3 Battery Charging Hub.
Using Air 3 Battery Charging Hub as powerbank to charge other external devices works fine.
2023-9-28
DJI Paladin
Necronomic Posted at 9-28 05:27
Hello there!
Thank you for your response. Please try to follow the steps above to stop the accumulating power and then check. Please keep us posted. Thank you.
2023-9-29
Necronomic
Sweden
DJI Paladin Posted at 9-29 20:05
It still doesn't work. Not charging when I stop the accumulating power. It's either yellow solid light or no light at all on the charging hub.
30W from powerbank works fine, and also fixed 65W AC-adapter.
I've also tried 3 different USB-C cables, same issues remain.
2023-9-30
DJI Paladin
Necronomic Posted at 9-30 08:53
Thank you for keeping us posted and we're sorry for the trouble. Can you please create a video showing the issue so we can check it further? You may upload the video via Google Drive and send the link to us. Thank you for your cooperation.
2023-10-2
KLRSKIR
Flight distance : 28368625 ft
I use several different Mophie power banks without issues.
2023-10-2
JodyB
Flight distance : 302536 ft
I don't know how relavant this may be, but an issue I had when sourcing a 100w charger is that the first one I bought, only support PD power output. I could connect the charger to the charging hub and the light would turn on yellow and then go out completely. No charging. I looked at the chargers that DJI has in their store both the 65w and 100w (neither in stick at the moment) one and both was listed as supporting PD and  PPS power output. I then found a charger that supported both types of power output. After looking at the description of the power bank you have in question, I see it only supports PD power output. I do believe from the experience I had, this could possibly be your issue but you are dealing qith a battery bank charger and not a wall charger. As I learned its not exactly about how much power is output but how it's delivered.
2023-10-2
TotalNewb
Try plugging your powerbank into the wall plug as if charging your powerbank up, then plug a usb-c into the hub and see how the charge goes through, it might give you an idea that it is about the in and out specs of the powerbank
2023-10-3
Necronomic
Sweden
KLRSKIR Posted at 10-2 10:30
And you charge from Mophie powerbank to Air 3 battery hub at 100W?
2023-10-3
Necronomic
Sweden
TotalNewb Posted at 10-3 03:14
I can't do that since my powerbank 100W output are also the input for charging
2023-10-3
Necronomic
Sweden
JodyB Posted at 10-2 10:38
Hi JodyB,
Good input! It may actually be that way. Too bad I can't see anything about PPS on the battery hub or the official DJI chargers.
Can anyone at DJI confirm this?
2023-10-3
KLRSKIR
Necronomic Posted at 10-3 05:52
Yes, specifically this one. It has a 100W AC output that I use with the 100W DJI charger. I also use Jackery Powerstations when I'm in the field for extended periods of time without juice.
2023-10-3
TotalNewb
Necronomic Posted at 10-3 05:54
Maybe try just one or 2 batteries in hub to see what happens
2023-10-3
JodyB
Necronomic Posted at 10-3 05:56
Hi JodyB,
While I can't confirm that PPS is required other than my own experience, if you look at the overview of the official DJI 100W charger, it does list PPS as one of the two power output modes. Have a look here. Also the official DJI 65W charger here.
What gets me is that no charger is included with the A3, like we all just have scads of these stashed in a drawer somewhere that meets these requirements. I've read others posting that they used a 20W charger that for some unkown reason quit charging the hub after a period of time or just not at all. Makes me wonder sometimes.
2023-10-3
JodyB
Something I just thought of, may not be anywhere close to the issue, but when you plug in your battery hub into the power bank, does the power bank show signs of it charging off the hub?
2023-10-3
Necronomic
Sweden
TotalNewb Posted at 10-3 07:59
I've tried only charge one battery on the hub, it's still not charging, this is so strange...
2023-10-3
Necronomic
Sweden
KLRSKIR Posted at 10-3 06:59
Link is not working, but i've google after powerstation pro ac zagg, it doesn't seems to be a 100W powerbank?
I think it's totally working with an powerstation using correct ac-adapter.
2023-10-3
Necronomic
Sweden
JodyB Posted at 10-3 08:04
I've just recevied new ac-adapter today, with PPS support and it charges the battery hub just fine.
I think its my powerbank fault... But Mophie powerbanks seems to work so I'm a little confused here.
I saw now both the 65 and 100W official ac-adapters was supporting PPS too, so I guess you're totally right.
Thanks Jody!
2023-10-3
Necronomic
Sweden
JodyB Posted at 10-3 09:22
The charging hub actually charge the powerbank instead... I know, strange right
2023-10-3
JodyB
Then my thoughts on PPS being the issue isn't correct. Seems like I've read about this issue with the previous generation of this controller but I sadly can't remember what came of it though
2023-10-3
JodyB
On another note, a lot of the larger Anker branded power banks seem to work also. Ian from London did a review on a lot of anker stuff and a power bank brand called Omnicharge I think was the brand, but I looked at the Omnicharge ones and they were crazy expensive.
2023-10-3
virtual
Flight distance : 4897142 ft
Czechia
As I wrote in that other thread, 20 W charger is "basic" 6 Volt power supply used to charge 1 cell lipo battery (3,7 V) in phones while Air 3 has 4 cell battery (14,8 V) and the hub is made to be powered by 20 Volt power supply that can deliver at least 65 Watts.
2023-10-3
JodyB
In this case, the specifications of the sandberg power bank in question states that its port 3 (USB C out) can do a max of 20v/100w so it shouldn't really be an issue.
2023-10-3
JodyB
Were you using port 3 when trying this Necronomic? I'm assuming you were since you mentioned that the port was combined input/output.
2023-10-3
virtual
Czechia
Necronomic:   It is strange that 100W output works fine plugged in to drone. Have You tried other power supply (65 W wall charger) with the hub?
2023-10-3
JodyB
I think the issue here is either the hub or the bank is getting confused on which should be input and which should be output.
2023-10-3
Necronomic
JodyB Posted at 10-3 10:16
[view_image]
Yes, of course
IN/OUT3 is the only one with 100W output. I'll make a quick video so you guys can check, I'll keep you updated.
2023-10-3
KLRSKIR
JodyB Posted at 10-3 10:19
100% agree.
2023-10-3
Necronomic
virtual Posted at 10-3 10:16
65W regular adapter for pc works fine.
So does the new 130W AC adapter i've got today, it support PPS
I'll make a quick video so you guys can check it out.
2023-10-3
Necronomic
I hope not, because this is already confusing---
2023-10-3
JodyB
Necronomic Posted at 10-3 10:27
I know what your saying and I know I've read about another issue like this but can't for the life of me find the post.
2023-10-3
TotalNewb
Necronomic Posted at 10-3 09:25
I can only imagine it is something to do with this PD3.0 QC3.0 Dji does say this is needed but I cannot see it in the specs of your powerbank, I can confirm Anker 737 powerbank with Anker 765 cable works fine
2023-10-3
JodyB
TotalNweb maybe onto something here. The Sandberg power bank description doesn't mention anything about what version of PD or QC it supports, nor does it mention PPS. PPS wouldn't have anything to do with negotiating input or output, that would be PD's job. PPS (programmable power supply) is just an extension of PD to allow more granular scalability of the current being requested. PD does the actual negotiating and if its an older version, may not have the necessary ability to allow negotiation between power input and power output of a combined port. That would actually make sense. You plug in the battery hub into the bank, the hub makes a request, are you input or output? The hub never receives a response so it assumes its input (receiving) and sends it power.
2023-10-3
Necronomic
Sweden
Just finished a short video here in pretty dark enviroment, sorry in advance!
https://drive.google.com/file/d/1EJO-pB7xS7nAduScDseoOz5UEqbpGG7M/view?usp=sharing
Any help or idea would be appreciated!
2023-10-3
Necronomic
Sweden
DJI Paladin Posted at 10-2 03:01
Hi,
Video are now created, link here:
https://drive.google.com/file/d/ ... 7M/view?usp=sharing
2023-10-3
JodyB
Necronomic Posted at 10-3 11:34
Hi,
Requested access. Might consider changing it to those with the link. If you aren't comfortable with that, I totally understand.
2023-10-3
Necronomic
Link updated, sorry about that:
2023-10-3
JodyB
Thats exactly whats happening. For some reason, whether it's PD (Power Delivery) version or what, one or the other is role confused and the hub is charging the battery bank. I'm not sure if you can return that battery bank, but it it was me I would consider returning it and finding one that has either a single usb c output or with 3, at least enough output only ports to support charging the hub and perhaps your controller as well. In any case, a dedicated charge port to charge the bank back up and not a combined port. It can have other USB ports if you need those as well like for a phone, but just remember, anything extra plugged into it will try to spread the current amongst all devices.
2023-10-3
TotalNewb
JodyB Posted at 10-3 11:56
Yep looking like that, possible last throw of the dice would be, plug in powerbank to empty hub, then add battery after to see if it tricks it into charging the other way round
2023-10-3
12Next >
