Setup compatibility Canon R6 Mark II
1393 3 2023-9-28
fanscbb11d21
Hello everyone,
I'm about to buy an RS3 but I'd like to know if any of you are using the following setup on an RS3:
- Canon R6 Mark II
- RF-EF conversion ring
- EF 24-70mm f2,8 L II lense
- Atomos Ninja
I'd like to be sure that the camera doesn't touch/block the RS3. In depth for example? And if this setup can be balanced correctly.
Thanks in advance
Tom
2023-9-28
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. The weight of the EF 24-70mm F2.8 lens and RF-EF conversion ring paired together is greater than the weight of the R6II camera, if you are trying to use this with the RS3, there may be a collision with the horizontal roller arm, and if the lens still needs to be zoomed in. The recommendation is to use the DJI RS 3 PRO to get a better use out of it. Hope this helps. Thank you for your valued support.
2023-10-2
fanscbb11d21
DJI Paladin Posted at 10-2 02:33
Thank you very much for your assistance.
2023-10-30
DJI Paladin
fanscbb11d21 Posted at 10-30 09:35
You are most welcome. Please don't hesitate to reach us if you have other inquiries. Have a nice day!
2023-11-2
