Well, maybe the first Mini 4 Pro DOA...
1544 27 2023-9-28
segrex_it
Flight distance : 396952 ft
I didn't even get to make the first real test flight. Vertical gimbal motor stuck, error 1D010003.
Even trying to move the motor by hand with the drone off, you can feel some resistance.
I have opened the ticket CAS-14372467-Q5Q1G9, please handle it as soon as possible, the drone is literally new.
Thank you
2023-9-28
Potato mini
Flight distance : 7275348 ft
open a warranty case with DJI
2023-9-28
Blériot53
Flight distance : 6260935 ft
Even the most rigorous Quality Testing will miss the occasional dud. Disappointing for you, to receive one.  But you should have no difficulty getting a replacement under warranty.
2023-9-28
RobZilla
Flight distance : 1057844 ft
Sorry to hear/read the news. I'm assuming you removed all the protective labels including the protective foam behind the gimbal?
2023-9-28
DJI Diana
Flight distance : 2408 ft
Hello, there. We're sorry for the unpleasant experience with your recent purchase of DJI Mini 4. If the aircraft is faulty out of the box, you may request a replacement instead. If you wish to proceed with the replacement request, you may simply apply through this link After successfully creating a new case, please let us know about the latest case number and the existing one will be canceled.  hope this information helps. We look forward to hearing from you.
2023-9-28
Space Dream
This is really a disappointment and I wish you a fast express replacement delivery
2023-9-28
segrex_it
DJI Diana Posted at 9-28 13:41
Thanks Diana. I need to close the case already opened to apply for the replacement?
2023-9-28
segrex_it
Done:
NEW CASE FOR REPLACEMENT: CAS-14373041-T7M8S3
OLD CASE (DELETE IT): CAS-14372467-Q5Q1G9
Plese let me know for the shipping label.
Thanks!
2023-9-28
MHM
Just return it from where you bought it and get a new one......No need to open a ticket from DJI.  If you bought from DJI they will just replace it with a new one.
2023-9-28
DJI Diana
segrex_it Posted at 9-28 13:55
Done:
Thank you for the update. The previous case has been successfully canceled. Please check your email including spam/junk folder for the shipping label. Should you have further concerns, please let us know.
2023-9-28
agia57
Flight distance : 553822 ft
Dirty Bird Posted at 9-28 14:43
You definitely removed the foam shipping insert from behind the camera?
^ This -- I missed the foam the first time myself and got a gimbal stuck error.  Looked again and saw that I missed it...
2023-9-28
segrex_it
agia57 Posted at 9-28 18:51
Thanks but... Yes, i removed the foam and all plastic wraps before turning on the drone for the first time :-)
2023-9-28
segrex_it
MHM Posted at 9-28 15:04
Not directly from dji, but from an authorized online reseller (a dji partner)
2023-9-28
Bigplumbs
Flight distance : 620164 ft
segrex_it Posted at 9-28 19:45
Yup better to go to who you bought it from DJI will most likely do your head in for this sort of thing
2023-9-28
MHM
Just throw away the foam it’s not needed.
2023-9-28
Blériot53
MHM Posted at 9-28 20:39
Just through away the foam it’s not needed.
I always replace the foam insert after every flight, to keep the gimbal steady during transport.
In addition to the clear plastic cover.
2023-9-28
Space Dream
Blériot53 Posted at 9-28 23:57
I do this also often
2023-9-29
DowntownRDB
Flight distance : 1722 ft
Same procedure here also.  Just a good safety precaution.
2023-9-29
Blériot53
DowntownRDB Posted at 9-29 10:44
Absolutely. If it wasn't there to ensure safe transport, why would DJI put it there in the first place.  Makes total sense to follow the same procedure. And it's now a habit to insert and remove it between flights.
2023-9-29
DowntownRDB
Blériot53 Posted at 9-29 11:09
Exactly.  I also figured that the weakest point on the drone is most probably the gimbal assembly so why not protect it as best we can.  Always better to be safe rather than sorry later.  Easy to put in and easy to take out.  Not sure why they didn't come with the earlier DJI drones.
2023-9-29
Blériot53
DowntownRDB Posted at 9-29 11:15
The Phantom 4 had a foam collar. I flew mine with it on, once or twice, by mistake.
2023-9-29
NBGRobbo
Flight distance : 12349 ft
Not long before we see refurbs then
2023-9-29
DowntownRDB
Blériot53 Posted at 9-29 11:30
I never hand any of the Phantoms as I started with DJI Mini.  I had the original Skydio and then upgraded to the Skydio 2+  None of those had any foam.  Accidentally, I did take a fam flight with the Mini and it still had on the gimbal cover.  Fortunately, I wasn't filming and didn't move the gimbal around.  I didn't notice it was still on until I landed.  No warning came up on DJI Fly App either.  So guess I was lucky I didn't mess up the gimbal.
Looking back I don't know why all of the drones didn't ship with that foam gimbal protector.
2023-9-30
Mullheliflier
Flight distance : 12305135 ft
These things unfortunately sometimes happen. My brand new Mavic 3 was faulty on Christmas Day. Sorted by DJI in a couple of weeks. I hope you get yours back quickly.
2023-9-30
Blériot53
DowntownRDB Posted at 9-30 09:45
The Phantom 4 also had a plastic gimbal clamp, or lock. It was absolutely essential to remove that before flight, or serious gimbal damage could occur.
2023-9-30
Space Dream
@ DJI Admins - Can i get a spare "foam" to protect the Gimbal part ?
2023-9-30
DowntownRDB
Blériot53 Posted at 9-30 22:48
I hear you.  I think I was just plain lucky that the Mini gimbal wasn't rendered inoperative.
2023-10-1
Blériot53
DowntownRDB Posted at 10-1 02:43
2023-10-1
