My DJI Phantom 2 Vision does not hover well
3134 6 2014-12-9
jon.s.ratcliffe
South Africa
I power up the Phantom 2 Vision. Wait for the slow flashing Green light and then get it to take off.
I then take it up 5 metres and try to get it to hover. Every time I try it sticks around for 1 or two seconds and then accelerates off to the left or right. If I let it go, it goes for 10-15 metres before I regain control.
Am I doing something wrong? Is the GPS not correctly locked?
Thanks
Jon
2014-12-9
Gerry1124
Did you do an IMU calibration and then the other calibrations?
2014-12-9
DJI-szz
China
hello ,jon,
had you try to connect P2 V to the PC, use assistant software?
The assistant software_3.6 will help you to find out the cause.
Please contact with DJI if need help.
2014-12-9
DJI-szz
China
The compass module,the IMU and stick need to be calibrated correctly.
If not the copter can't fly normally. Please kindly tell us how the LED light flicker.
2014-12-9
Tony
Flight distance : 2856060 ft
This definitely sounds like calibration issues. Need to get it connected to a computer and run the tests and calibrations. Please let us know what you find out after you calibrate.
2014-12-10
philml420.email
Funny, I had similar proble on my vision, my case was, as it had a mind on its own sometimes, later on was happy to know that it was just a camera settings on the app, look into the vision cam app settings its right above the manual camera scroll, hope that fixes the problem
2015-1-24
bjr981s
Flight distance : 139698 ft
Did you calibrate the Transmitter controls in the RC Ap and then in the Assistant App?
If the Controls are not calibrated it may cause the result you are experiencing
An easy way to tell is to test on the ground. Once you receive the GPS lock signal check the green flashing LEDs.
If it flashes once pauses and flashes Once and repeats all is OK.
If it flashes Green twice then a Pause it means that the controls are not centred.
Once the transmitter sticks are off centre the flashing Green will become a double flashing Green.
If yours is doing this with the sticks centred it requires a calibration.
Cheers
2015-1-24
