Upgrading firmware fpv
785 6 2023-10-3
djiuser_O3LNMlqGpwyn
Flight distance : 1706568 ft
Ok using assistant 2 consumer, windows 10.  Can see drone,  it collects update from net then dies trying to apply it to drone.
Issues with this since i got it.
Have error error 5-100-4.
It's as if the software cannot write to the drone.  Just picked up Avata, updated no problem, also, updated googles,two controllers, again, no problem.
Does the fpv need sd card formated in a certain way or acces?
2023-10-3
DJI Paladin
Flight distance : 318 ft
Hi there. We do apologize for the trouble. Kindly please enter the "Device Manager" on your PC and find "Network adapters">"remote NDIS based Internet Sharing Device" If this setting was disabled, please enable it and check if the issue persists. Please keep us posted. Thank you.
2023-10-3
K it is enabled, there is an issue under events.
2023-10-3
keep getting stuck at the writing to drone.  Downloads fine.
2023-10-3
Ok, so, anyone have an idea?  Why can I update my avata, but not the fpv drone?
Should be the same, right?
2023-10-5
DJI Paladin
djiuser_O3LNMlqGpwyn Posted at 10-5 12:53
Hi there. Sorry for the late response. I'm afraid that you may consider sending the unit in for a proper diagnosis. You may contact our support team to start up a ticket at https://www.dji.com/support . Thank you for your understanding and support.
2023-10-14
Ok, had reinstalled third time. The slabvcp.inf failed to install.  Could this be the problem?  What does it do?
2023-10-15
