Assistant 2 doesn't see Inspire 3, Cant activate ProRes
2141 5 2023-10-4
honda821
Flight distance : 1030020 ft
Hi There
I have just bought ProRes Cdng license but I cannot connect to the inspire 3, all the latest firmware and software. I have tried 2 macs and 1 PC
Is there any other way to activate with my code? I need to shoot in Raw this weekend
Thanks
2023-10-4
honda821
Solved, Used different cable and worked, faulty cable
2023-10-4
DJI Diana
Flight distance : 2408 ft
honda821 Posted at 10-4 03:34
Hello, there. We apologize for the inconvenience that it may have caused you. However, we're glad to know that everything is working fine. Should you have further concerns, please keep us posted. Thank you for your support.
2023-10-4
Josephsmith
I was in the same boat as you before, I realized that there are 3 usb-c outlets on the I3, you need to plug the wire into the right one
2023-10-4
djiuser_Cofgamk12oEa
Flight distance : 1881503 ft
I'm running into a very similar issue. I cannot get the drone to show up on the Assistant 2 app to install the Raw license. Can you send a picture of which cable is meant to plug into a computer and which usb-c port to plug into the inspire 3? I've tried multiple cables and every ubs-c port
2024-7-4
Lorimer314
Flight distance : 79744 ft
1. Unknown Use (the manual list it as an "Expansion Port" but then does not mention it in the "Expansion Ports" section, FAQ is specific that it is USB 2.0 port)
2. 4G Cellular Module Port
3. Assistant Port (Firmware and License)
As far as I know, if you are in the US (or anywhere outside of China) port number 3 is the only one you will ever really use for anything.
2024-9-6
