Unable to login via Cloud API
Home / Events /
526 1 2023-10-6
土居豊明
Japan
Model: Matrice 300 RTK
Cloud Service: AWS
I Created an environment for AWS Cloud API.
I issued application key on dji Developer and Set the Cloud API key in "src/api/http/config.ts" on the front end with,
When I tried to login from RC, I got an error,
I could not log in.
Why the error occur ?
Could you take a look at the screenshots?
MQTT has not been created yet.
Is MQTT required in the environment for the process to login?
2023-10-6
DAFlys
Hi! You might be better off posting your question in the 'Developer' section of this forum.  That is way more active.    -   From https://developer.dji.com you can click Forum to access it or a direct link to it is - https://forum.dji.com/forum-139-1.html?from=developer
2023-10-13
