Mini 3 Pro - RC with large dashed frame ?
1031 9 2023-10-7
Space Dream
I would like to know what this big dashed frame means ?
The frame usually appears only very briefly and disappears again
2023-10-7
Bashy
Flight distance : 2354357 ft
I had forgotten what it represents, forum staff explained it to me and btw, youre colour blind as its yellow, not red ;)
2023-10-7
Space Dream
Bashy Posted at 10-7 03:32
YES maybe LOL I changed it to dashed frame
2023-10-7
Bashy
From DJI Mindy
Hi there, it represents the average metering: Divide the screen into multiple regions, and perform independent metering for each region, and then calculate the average metering value of the entire screen based on this.
2023-10-7
Drone.Hunter
Flight distance : 4537612 ft
Kazakhstan
If you press in the middle of the screen, a focus square will appear there. And if you press outside of this frame, it will start blinking, informing you that it cannot focus there.
2023-10-7
Space Dream
Dirty Bird Posted at 10-7 11:28
In the settings there is an option for "Frame Guide".  I believe it is in the Camera Settings section.  You must have it enabled.
I don't have any subframes enabled, my display is empty of subframes when flying,
only when I tap the outsides of the screen this big dashed frame pops up and I
have no idea what that means or what function it triggers.
2023-10-7
Space Dream
Bashy Posted at 10-7 06:23
From DJI Mindy
Do you understand what is meant by this Explanation ?
If the frame is active, does it then perform an exposure measurement over the entire screen content
OR do I still have to do something myself ? Do not understand the division into sectors,
since the frame shows none and spans almost the entire screen.
2023-10-7
Bashy
Space Dream Posted at 10-7 12:29
Best explanation is that in evaluative metering, the camera breaks the image frame down into a number of different zones (you do not see the actual zones), measures the amount of light in each zone, and then analyses the findings to determine the optimal exposure required, you do not need to do anything.
I think that when you tap the screen and the exposure lock shows, it then changes to spot metering and you can then dial that in for that specific area of the shot, i could be wrong on that part though but that is my understanding of it but i am sure someone will correct me if i am wrong.
2023-10-7
DJI Gamora
Hi, Space Dream. Thank you for reaching out. The yellow dotted box on the DJI Fly camera view indicates the metering area. This box appears when you tap an area outside the yellow box. At this point, metering is conducted within the frame.
2023-10-8
Space Dream
DJI Gamora Posted at 10-8 07:49
Can I update the measurements again & again by activating this frame several times according
to some new light situation or is this only set once and then remains permanently stored  ?
2023-10-8
