Being very excited about the prospect of easily capturing True High Resolution images on the Air 3, I want to make it really clear that DJI knows that it’s user base would appreciate such a feature. If you feel having an automated ability to capture an approx. TRUE 65MP image from a stitch of 70mm images matching a 24mm view is a useful feature please vote accordingly in the voting section of this post.
DJI – THE CASE FOR AN AUTOMATED HIGH RESOLUTION CAPTURE MODE USING THE 70MM LENS ON THE AIR 3. The Air 3 is the first drone down from the Mavic series that has the ability to employ a Telephoto lens, in this case a 70mm 3x Tele. This now gives the Air an ability never before seen in the mid to lower drones and that is being able to stitch a grid of 70mm tele images to make a much higher resolution STANDARD WIDE ANGLE image. This is just not possible by just using the 24mm wide lens. The resolution is 12MP for a single 24mm shot, this increases to around 65MP! using the 70mm to take images covering the same area as the single 24mm wide angle lens. With the AIR 3 you have an equal or better camera to a DSLR in the air! This ability to now capture 65MP 24mm effective images is groundbreaking for this type of drone because you could never do it before automatically. All you could do is capture extremely wide and often unwieldly images combining a stitch of wide angle images via the Panorama mode. I think it’s important this feature is not achieved by just giving the 70mm Panorama access (though for some use cases that would be cool) but is really about giving the photographer a precise 24mm view they can choose knowing that they can quickly capture a 16 image grid of 70mm images to provide the 24mm view but in stunning resolution.
You could allow the photographer to just crop the image they want out of a 360 or 180 pano taken with the 70mm but there are issues with that… · You would need at least 9x more images than compared to doing a panorama in 24mm mode · This would require A LOT of images and take up a lot of space · You would be introducing a lot of time in which elements in the scene could move e.g, clouds, vehicles etc however most external stitching software has very effective masking features to reduce issues caused by this. Also when taking drone photographs you are very conscious of time and people around you, you don’t want to prolong your time in the area waiting for your drone to take a lot of unnecessary images. To me the better option is not necessarily include this option as a Pano function but have an icon always on the main screen being a “True High Res” icon whenever you are in Photo Mode. In it’s simplest form you are flying along you find a view you like using the 24mm camera you push the “True High Res” icon and the drone (through just a simple algorithm) based on where the lens is pointing takes a grid of 16x 70mm images to cover the view of the 24mm lens. You could have in settings the ability for the user to then have a stitch done right there and then or just forget that and the user can stitch later in a higher quality using PTGUI or Panorama Studio for example. We have this ability right now (see below) it just needs automating. Having flown my drone in the weekend and spending a whole day taking stills one thing sticks in my mind. I want to be as quick as I can I don’t want the drone in the air for longer than necessary and I don’t want to attract the attention of any passers-by. By having a dedicated quick “True High Res” mode I can quickly and easily get in get the grid taken exactly where I want it and go.
So we have done some tests… A user went out and took a single 24mm image. Then using the 70mm lens positioned the camera in the top left corner of the 24mm frame and proceeded to take grid of images going 4 across and 4 down (in this case the user used a few more but covered the area well.) We then stitched the images to form a single high resolution image. Here is a comparison of the stitched 70mm and single 24mm views….
At this size they look almost the same quality, the 70mm stitch does introduce some compression but I don’t see that as an issue.
Here is a close up comparison of the two images. Left hand is the a 200% crop of the stitched series of 70mm images and on the Right hand side is 24mm single shot at about 490% to match the scale of the stitched image…
As you can see the 70mm stitch is far superior as you would expect it to be. If printing the 70mm stitch at 300DPI this print would be 817mm x 585mm and be able to withstand close examination, something pretty much unheard of for a 24mm view from a drone. In it’s 24mm 12MP form you could do the same print quality but at only 341mm x 256mm.
DJI this really seems like an easy solution to provide users of the Air 3 a quick and reliable method to rival DSLR quality images from the air and be able to produce something really special. I really hope you will add this feature to the Air 3 and potentially any other drone in the DJI family that has a telephoto lens.
Many thanks
Andrew Busst
