SDK registration issue
411 2 2023-10-10
djiuser_mVAXikaiSPuj
Czechia
Hi, I'm trying to run the Swift sample code app. I followed the instructions in the official tutorial. I created my own app key in the DJI developer centrum, but when I try to run the app, it prints out "SDK Registered with error" in the logging console. Normally, the text should be followed with an explanation of the error, but the appRegisteredWithError method gets called with a nil value in the error parameter, so there is no further information about what went wrong. Any suggestions? I'm using Xcode version 15 and iPhoneSE(3rd gen) as a device .
2023-10-10
NickFury1
Ukraine
Hello there, I'm searching for similar info. Did you find anything already?
2023-10-25
Czechia
NickFury1 Posted at 10-25 23:45
Hi,
unfortunately, I couldn't find anything, so I was forced to switch to an Android device and used the DJI Mobile SDK for Android and it worked (after many changes in the sample code needed to be made, cause you know, DJI SDK...).
2023-11-15
