connected device not bound to aircraft
696 10 2023-10-10
DJIdoesitwork
OK Im new to the DJIs. So far, very, very disappointed. I have a brand new, not second hand, Mini 2 SE with base model RC, again bought new from amazon as a set. I have flown it for a total of 11 minutes, no problems. This morning I arrived at the beach for a vacation and it wont fly. Error message says "connected device not bound to aircraft. Connect to bound device: Remote Controller (SN: 6nyxl*****01pa) to continue or perform the following steps" then it gives the options to "unbind device" or "cancel".
First my RC has a tiny serial number printed on it and it matches what the error message says is the correct serial number RC. SO, I dont get what is wrong. If I select cancel then I cant fly. If I select unbind device I folow the proccess until I get an error saying "server unavailable". SO that is it. I call the tech support and they had me send them a milion screen shots and confirmed my serial numbers via cell phone pics and they said I should unbind and rebind using the DJI assistant +2 consumer app. Following those instructions I have run this app and it doesnt seem to do anything, it recognizes the drone and says it is all up to date. If I go to device management in the dji fly app it just says no device found, becuase I unbound it as instructed. It was present before unbinding. But it doesnt give me any option to rebind. It acts like it is not connected to the RC? Support does not seem to have any other ideas to offer me? Did I just throw away a couple hundred dollars?
2023-10-10
DJIdoesitwork
Using the DJI assistant i refreshed the firmware for both the drone and the RC. Then I uninstalled the go fly apk and reinstalled it. I logged back in and tried to connect the drone and the RC and I get the same error  "connected device not bound to aircraft" device manager still shows no bound device.
2023-10-10
DJI Thor
Flight distance : 13602 ft
Hi there, sorry to hear the experience you came cross. Would you please share us your remote controller SN? We will help you to further check with our relevant team. Thanks.
2023-10-10
DJIdoesitwork
printed on back of RC below QRcode "6************A". This matches the serial number in the error code. edited out serial number per request.
2023-10-11
DJIdoesitwork
drone serial number 1************8. edited out serial numbers per request
2023-10-11
Sean-bumble-bee
Flight distance : 15997 ft
DELETE THOSE SEIAL NUMBERS ( EDIT THE POSTS) AND SEND THE INFORMATION TO THOR VIA A PM.
2023-10-11
DJIdoesitwork
Sean-bumble-bee Posted at 10-11 04:38
edited per request. and sent PM
2023-10-11
Sean-bumble-bee
DJIdoesitwork Posted at 10-11 08:21
ok
2023-10-11
DJI Thor
Thank you for sharing, we replied you via PM. Thanks.
2023-10-11
DJIdoesitwork
I have given up. I returned the item to the amazon seller and have received a full refund.
2023-10-12
cyan
Ban Posts
Flight distance : 202326 ft
1-7 16:23
