Mavic 2 Pro in 30FPS
1049 4 2023-10-11
mpresutto
Flight distance : 732287 ft
I was recently contracted for some videos and the spec sheet requires 29.97FPS. Does the Mavic 2 pro shoot "true 30FPS" or is it 29.97?
2023-10-11
DJI Gamora
Hi, mpresutto. Thank you for reaching out. Let us confirm this with our relevant team. We'll let you know once we receive an update.
2023-10-11
DJI Gamora
Hi, mpresutto. Thank you for patiently waiting. We have confirmed that the frame rate is just 29.97. When the NTSC system is applied to black and white displays (Luma component), the frame rate is indeed 30 fps/60 Hz. However, after the chroma component is added, the subcarrier of the chroma component and the original brightness component are modulated. Due to the inconsistent frequencies, this will lead to the generation of a beat frequency. The solution is to change the frame rate to 30000/1001 (29.97). Hope this helps.
2023-10-11
mpresutto
DJI Gamora Posted at 10-11 23:58
Thank you.
2023-10-12
DJI Gamora
You're most welcome, mpresutto. Should you need further assistance, please don't hesitate to reach us again here at DJI Forum. Have a nice day!
2023-10-12
