How to find FAA remote id code
53216 38 2023-10-11
ThrasherG
I have a mini 3 pro and it has all the latest updates, I was looking on the FAA drone registration site and it now gives me the option to state which of my drones has the remote id capability. When I select the mini 3 pro and state it has the option, the FAA page then asks for the actual remote id serial number. How do I find that? I have not enabled remote ID on the drone, I understand it just gets enabled as part of a firmware update. So where do I look to find the remote id code so that I can enter it into the FAA drone registration site?
Regards Gary
2023-10-11
ThrasherG
Dirty Bird Posted at 10-11 13:17
Enter the drone serial number.  You can find it on the box label, or from within the Fly app.  Allow aircraft & RC to connect, then enter Camera View, click the 3 dots (...) in the upper right corner > About > scroll to bottom.
Many thanks, I assumed it was a FAA unique number, didn’t realize it was the drones serial number. Will try it in the next day or two.
Regards Gary
2023-10-11
DJI Gamora
Hi, Gary. Thank you for reaching out. If the drone has a 20-digit alphanumeric serial number (always prefixed with 1581F) like the Mini 3 Pro, in this case, the Remote ID serial number is the same as the aircraft serial number, and generally the same as the flight controller serial number. You can check the serial number of the drone in various ways:
• Serial number on the box sticker Note.
• Serial number inside the battery compartment or elsewhere on the fuselage of the drone Note.
• Serial number inside the DJI flight control app.
• Serial number inside “Available networks” of the WLAN Note.
Hope this helps.
2023-10-11
Shayne Lory
Flight distance : 751407 ft
Simply not true. I enter my serial number and the FAA says it’s not a valid remote id number on my FVP drone
2023-12-29
djiuser_dXQRk3RiBdjK
Shayne Lory Posted at 2023-12-29 20:22
I am running into the same thing. I have registered drones before, so I am familiar with the process, and I keep getting the same error for every drone I try to register. I even went as far to try every combination of zero vs. O, and kept getting the same error.
2024-1-31
Sander van der Bie
Has anyone managed to figure this out? I've been asking DJI Support for help, who stated it is '158 + controller serial number + 0', but this does not work for my Mavic 2 Zoom.
2024-2-4
Shayne Lory
Sander van der Bie Posted at 2-4 06:56
I actually did come up with a solution for this. I read it on another thread in the Forums. I cannot remember what numbers I used in front of my serial number. I will look at it tomorrow when I get home and can get logged in
2024-2-8
Hoffgoat
Shayne Lory Posted at 2-8 19:37
Hello Shayne -
Any luck on finding out how you got the correct set of numbers for remote serial ID to register with FAA? I have the same prefix 37QB.... as the above user and nothing is working to make it happy.
2024-2-20
DJI Tony
F
Hoffgoat Posted at 2-20 14:12
Hello Shayne -
Hi, Hoffgoat. For an aircraft with a 14-digit SN, you can get it by adding "1581F" to the 14-digit flight controller SN then add "0", and the total number of digits is also 20: 1581FXXXXXXXXXXXXXX0. Have a nice day.
2024-2-21
shawnik
DJI Tony Posted at 2-21 00:47
Hi, Hoffgoat. For an aircraft with a 14-digit SN, you can get it by adding "1581F" to the 14-digit flight controller SN then add "0", and the total number of digits is also 20: 1581XXXXXXXXXXXXXX0. Have a nice day.
Thanks DJI Tony, that worked! I have a DJI-FPV that i couldn't register and your suggestion did the trick. Good for another 3 years.
2024-2-26
DJI Tony
shawnik Posted at 2-26 21:52
Awesome. I'm glad to know it helped. You can always reach us if you need further assistance. Have a great day ahead.
2024-2-27
djiuser_hxU5CFXpFwNK
DJI Tony,  Thanks for posting how to get RID working with FAA website!  Now I just need to get the remote ID error off the drone.  I'm going to try updating again.
2024-3-28
DJI Paladin
Flight distance : 318 ft
djiuser_hxU5CFXpFwNK Posted at 3-28 13:28
Hi there. Thank you for reaching out. Please confirm what specific DJI product you are using so we can provide you with an accurate resolution. We will wait for your response. Thank you.
2024-3-28
Noah Frankel
dude thanks so much ive been lost for like a half hour lifesaver
2024-5-18
DJI Tony
Noah Frankel Posted at 5-18 08:54
You are most welcome. I'm glad it helped. Please feel free to contact us if you have further concerns. Have a great day ahead.
2024-5-21
garethg13
Flight distance : 12018 ft
Thanks for sharing this CRITICAL info! quick google search brought me to this thread... thank goodness I read through happy flying!
2024-5-22
DJI Tony
garethg13 Posted at 5-22 14:08
Awesome. I'm glad it helped. You may contact us anytime if you need further assistance. You may also visit the DJI support page using this link: https://support.dji.com/. Have a nice day.
2024-5-25
Michael Gray3
I am trying to register my Avata2 drone with the FAA. I am trying to use the 20 digit S/N beginning with 1581F. The app will not except the number at all. What can I do?
1581f6w8a244noa3zt6m
2024-6-2
Michael Gray3
What is going on with the FCC website to register drones. I have been trying for 4 days to register my new dji avata 2. I can't get past the S/N it said its invalid number.
I have read all the comments on this subject and the remedies talked about. I am using the 20 digit number starting with 1518F. It won't even except the first digit before red letter message saying invalid number.
I am beginning to think the federal government has made it impossible to fly dji drones due to political friction between countries. What's going on???
1581FGW8A244NOA3ZT6M
2024-6-3
fansf240c01f
Flight distance : 12536706 ft
Michael Gray3 Posted at 6-3 17:18
You need to make sure your serial number is correct. DJI does not use I's or O's in their serial numbers, only 1's and 0's. So there is at least one error in the one you posted (not a good idea to share that publicly). If you purchased Care Refresh, just copy and paste it from the email DJI sent.
2024-6-3
Michael Gray3
fansf240c01f Posted at 6-3 19:09
Thank you so much it was the "o" that was the problem. I have waisted so much time on this simple problem.
2024-6-4
digitalgenius
thank you!!!!
2024-6-12
djiuser_b91igLGDPExv
I have a DJI spark and I don’t know how to get the remote ID SN please help
2024-7-2
robtee
Flight distance : 492605 ft
Why is this not on FAA site (or Dronezone site), DJI site, or somewhere easily accesible?
It's quite odd that the solution to making our drones and FAA accounts Remote ID compliant is to add 5 digits in front of our SN and a 0 at the end
2024-7-5
robtee
djiuser_b91igLGDPExv Posted at 7-2 20:38
The Remote ID code needs to be 20 digits
You'll need your SN first. Where to find it:
• Serial number on the box sticker.
• Serial number inside the battery compartment or elsewhere on the fuselage of the drone.
IF it starts with 1581F, and ends in 0 (zero), use that code.
IF it is just a 14 digit SN, add 1581F in front and 0 at the end, so it makes 20 digits total
2024-7-5
DJI Natalia
robtee Posted at 7-5 07:24
Hi there,
For FAQs about FAA Remote ID Compliance you can check on this link from our official website.
Link: https://support.dji.com/help/con ... ;paperDocType=paper
I hope this information has helped to clarify your inquiries. If you have any other questions, kindly let us know. Thank You!
2024-7-6
DJI Natalia
robtee Posted at 7-5 07:33
Thank you for sharing your resolution. This sure will help other users whose having the same issue. Have a safe flight always!
2024-7-6
djiuser_i6yFHLYAJGgU
Thank you very much the information you provided worked like a charm i appreciate it kindly.
2024-7-18
Jesus Arturo Aguilar
It worked for me too! Thanks
2024-9-8
DJI Tony
Jesus Arturo Aguilar Posted at 9-8 18:41
You're welcome. If you have other questions in the future, please feel free to contact us.
2024-9-8
Adam Ant
Thanks DJI Tony, That works
2024-10-4
DJI Tony
Adam Ant Posted at 10-4 10:32
You're welcome. We are glad we could assist you. If you have any more questions or need further help, feel free to ask.
2024-10-5
Joe Michaels
Simply not true. I enter my serial number and the FAA says it’s not a valid remote id number on my FVP drone[Image]
I know this is old thread...but my DJI Mavic 3 Pro drone serial number worked for me today when registering, found it in the Fly App on DJI RC controller. Also passed TRUST certificate (it's really easy after taking time to read all the lessons first + you get multiple chances to immediately change your incorrect answers ;) Happy Flying!
2024-10-13
Joe Michaels
2024-10-13
djiuser_MNqMYL2Hoot7
DJI Tony Posted at 2024-2-21 00:47
Just want to say thank you for the information. Been trying to figure this stuff out. Why don’t they just give us that information SOMEWHERE? I was starting to go out of my mind with this!!!
2-17 16:17
DJI Tony
djiuser_MNqMYL2Hoot7 Posted at 2-17 16:17
You're welcome. We're glad we could help you. If you have any other questions in the future, please feel free to contact us.
2-18 03:22
djiuser_nplY1qgcI3OD
I can't register a Phantom 3 Advanced. Can someone help me with the ID? I put the numbers that are on the sticker but it gives me an error.
2-20 07:49
2-20 07:49
Chad Hatcher
Not all heroes wear capes or are the subject in Foo Fighters songs but Tony my friend, you are my hero.
2-24 07:44
