Sam654
Flight distance : 132667 ft
DJI Gamora Posted at 10-13 23:08
Hi, Sam654. Thank you for reaching out. The reason why FocusTrack is disabled when using a wide-angle lens or ND filter is that mounting a filter (wide angle or ND) may affect the stability of the active track function. Can you please confirm if you already have an ND filter? If yes, please try it on your end because our relevant team believes that the firmware update has been rolled out to optimize this concern.
This afternoon was bright and sunny, so ideal to try with an ND filter.
I used the ND64 with both Spotlight and Active Track modes and it worked without a problem.
The only time it lost a target was when passing into shadows, because the shadows were quite strong on a clear sunny day and with manually set exposure, it did not adjust for them.
So I can confirm FocusTrack will work with ND filters.
