DJI Susan
Hi there, for your reference, the specs for the BS60 Intelligent Battery Station:
Input:
Voltage: 100-120 Vac,50-60 Hz/220-240 Vac, 50-60 Hz
Maximum input current: 10 A
Maximum input power: 1070 W
If you may prepare an additional power supply to charge the BS60 Intelligent Battery Station, check the power supply’s input voltage, and then select the corresponding input power.
If the input voltage is between 100 and 120 V, the input power range should be 750~1070 W.
If the input voltage is between 220 and 240 V, the input power range should be 992~1070 W.
Output:
TB60 Intelligent Flight Battery ports: 52.8V, 7A*2@100-120V, 8.9A*2@220-240V
WB37 Intelligent Battery ports: 8.7V, 6A
Output power:
100-120 V, 750.0 W
220-240 V, 992.0 W
We may not have a recommended generator but you may refer to the specs requirement above, thank you for your understanding. |
