Sam654
Flight distance : 132667 ft
Because the Mini series drones have a fixed aperture, this limits the control you have over exposure.
In general photography/videography you will have three veriables for exposure, Shutter Speed, Aperture and ISO.
But on the Minis you only have Shutter Speed and ISO that can be altered.
You ususally want to keep the ISO on the lowest setting to reduce grain. So on a sunny day your ISO can be 100, the minimum. Now the only way to stop overexposure is to increase the shutter speed.
In photography this usually isn't an issue (with the exception of some effects), but in video a fast shutter speed can make footage feel a bit choppy, because every frame is perfectly sharp.
you may think "what's wrong with it being sharp?" But acually in video a bit of motion blur makes things look smoother and more natural.
Ordinarily you can close down the aperture to reduce the light and shutter speed, but you don't have that option.
That's where ND filetes come in. They are essentially tinted lens covers, like sunglasses which reduce the amount of light coming in the lens. This allows you to slow the shutter speed, to allow motion blur, without overexposing the footage.
The rule of thumb often cited for appropriate shutter speed is about half your frame rate. Eg: @ 25 fps, 1/50 of a second. @ 30 fps, 1/60. @ 60 fps, 1/120, etc.
In stills photography you mostly want to avoid any motion blur, but in cases where you do the ND filers can be used. One common example is long exposures on waterfalls or waves. I'm sure you have seen those sort of pics.
Perhaps in sports you may want a tad of blur to give a dynamic impression of speed or movement.
So that's what ND filters do. It's totally up to you if you think you want or need them. |
