Understanding camera style values
593 3 2023-10-22
Tuxtard
Flight distance : 9975610 ft
Serbia
Hi,
Sharpness in Camera Style settings goes from -2 to +2. It is a bit confusing what minus values do. Do -1 and -2 values introduce artificial blur or they are just reducing sharpness? If so, should't the values be from 0 to 4?
2023-10-22
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. Setting a larger value in the parameter will result in a better performance in sharpness or noise reduction. For instance, you may need to increase the iSO value for exposure in the night shooting environment. Since the higher iSO setting amplifies the amount of noise in the image, you can set a larger value in noise reduction parameter in order to reduce the noise levels. A higher value of sharpness increases the contrast between edge pixels, giving a clearer appearance of the image. Hope this helps. Thank you for your valued support.
2023-10-22
Tuxtard
Serbia
DJI Paladin Posted at 10-22 16:15
Thank you for the info. So basically what you are saying is that -2 sharpness is the least processed setting while +2 is the most?
2023-10-23
DJI Paladin
Tuxtard Posted at 10-23 11:47
You are most welcome, Tuxtard. Yes, also it will depend on what shooting environment you at, you may have a test flight to see the best settings based on your needs. Hope this helps. Have a nice day!
2023-10-25
