212
DJI Paladin Posted at 10-25 23:24
Hi there. Thank you for showing interest in our new product Yes, this function is available when using the DJI Mic 2 Transmitter. Should you have other inquiries, please don't hesitate to reach us. Thank you for your valued support.
Dear Paladin, thanks for confirming that it is possible to record a stereo line signal using the 3.5mm input in the DJI Mic 2 Transmitter.
I have tested it and it does NOT work. The signal appears to be a mono signal.
I have tested it with a TRS and TRRS adapter as well, but it was always mono. Since I need to record a STEREO line signal using the 3.5mm input in the DJI Mic 2 Transmitter, I again kindly ask you, if this is possible or not? If yes, how does it work? Thank you! |
