Camera Catching Gimbal Guard on Startup!
neilfau06
Flight distance : 282799 ft
So I recently just fitted a new carbon fibre gimbal guard underneath the camera, but I've noticed when you start up the P3A the camera does its usual dance & very slightly catches the guard, does anyone else have this problem & should I worry about it?
2015-9-5
liningiv
Flight distance : 329409 ft
Did you really ask this question?
2015-9-5
Michael M
Flight distance : 1984898 ft
liningiv Posted at 2015-9-5 13:21
Yes he did.
2015-9-5
RedHotPoker
Flight distance : 165105 ft
Nothing should interfere with the camera travel or gimbal.
If the gimbal guard is rubbing the camera, it will have to be lowered somehow.
How else would it be effective? There are times when you will want the camera lens facing straight down.
RedHotPoker
2015-9-5
stephen.sanderl
In my "humble" opinion, as I read it so perfectly put, I don't feel gimbal guards are worth it. One of my favorite features of the camera is being able to look straight down and this essentially eliminates any chance of getting those shots.
Granted I see the benefits because like pretty much everyone out there, I've had the gimbal overload on a blade of grass, I feel that limiting the viewing angle of the highest selling point of this particualr model (the camera) is not worth it, and especially not worth the trouble of having to find a way to rig it so the camera doesn't rub on warm up.
Best of luck, my advice is get your money back and put it in a savings for potential gimbal or camera replacement.
2015-9-6
rayrokni
Flight distance : 8139875 ft
you must have a bad design!! i iuse one from uavbits.net, it does not interfere with gimbal or come into view of the camera looking straight down.
and yes you should be concerned
2015-9-6
RedHotPoker
This is pretty common sense, and shouldn't be too difficult to figure out. The unit is not made for your Phantom. 3
If it interferes with normal camera operation, or prevents the viewfinder from seeing everything in it's already limited path,
you kind of defeat the main purpose of a awesome camera platform.
So please, Contact the seller and see what they offer as an explanation or immediate exchange.
RedHotPoker
2015-9-6
Bobabc
Try flipping it over. I know it's silly but I had a friend with the same problem and that was the solution.
2015-9-6
rayrokni
Bobabc Posted at 2015-9-7 03:31
Try flipping it over. I know it's silly but I had a friend with the same problem and that was the so ...
actually it is not silly, u have made a very valid thing to try.  not all the guard are symetrical. good job
2015-9-6
