New DJI Osmo Pocket 3 Firmware Released (11/26/2024)
12345678Next >
90046 306 2023-10-26
DJI Support
Flight distance : 2408 ft
China
Overview
  • Date: 2024.11.26
  • Firmware Version: V01.05.10.01
  • DJI Mimo App iOS: V2.1.8
  • DJI Mimo App Android: V2.1.8
  • DJI Mic Mini Transmitter Firmware Version: V01.01.00.39
What’s New
  • Added support for DJI Mic Mini. Press and hold the Linking Button on a DJI Mic Mini transmitter for 2 seconds to link. Then, go to System Settings > Wireless Mic to select the microphone. Osmo Pocket 3 can connect up to two transmitters simultaneously, supporting both DJI Mic 2 and DJI Mic Mini.
  • Optimized wireless microphone audio settings. If stereo is enabled and only one wireless microphone transmitter is connected, Osmo Pocket 3 will duplicate the audio to both channels.
  • Added an option in settings to enable or disable the "Press and Hold Shutter/Record Button to Cancel Recording" feature. This feature is enabled by default.
  • Added the background download feature for files in the DJI Mimo App. To use this feature, update the DJI Mimo App to the latest version.
  • Optimized the Auto-focus performance.
  • Fixed some minor bugs.
Notes:
If the update fails, follow the steps for troubleshooting.
1.        Restart Osmo Pocket 3 and DJI Mimo.
2.        Enable Wi-Fi and Bluetooth on the mobile device.
3.        Connect Osmo Pocket 3 to DJI Mimo and try the update again.
Contact DJI Support if the update fails again.
Overview
  • Date: 2024.05.15
  • Firmware Version: v01.04.08.02
  • DJI Mimo App iOS: v1.12.0
  • DJI Mimo App Android: v1.12.0
  • DJI Mic 2 Transmitter Firmware Version: v04.04.05.13
What’s New
  • Added support for 4K resolution for UVC, and 3840x2160 25/30P output. ActiveTrack and recording with DJI Mic 2 are also available when livestreaming. Set the source video resolution in the live streaming software such as OBS before use. Make sure that the performance of the computer used for live streaming and the quality of the USB cable meet the requirements for 4K resolution. Live streaming with 4K resolution has higher requirements on system performance.
  • Added FPV-⊥ gimbal mode. When enabled, and if the camera is powered on or recentered, the camera will stay perpendicular with the touchscreen, which is suitable for quickly capturing subjects.
  • Added option for Auto Power Off. Never is now available.
  • Adjusted the order of Wearable Mode in the Control Menu. When Wearable Mode is enabled, the screen turns off automatically after 5 seconds.
Notes:
1. Connect the DJI Mic 2 transmitter to a computer to update the firmware. Follow the steps below to update:
  • a) Download firmware v04.04.05.13 or later from the official DJI website (https://www.dji.com/cn/osmo-pocket-3/downloads).
  • b) Make sure the transmitter is powered on. Connect the transmitter to a computer using the UCB-C cable.
  • c) Place the downloaded firmware update package .bin file under the root directory for the transmitter.
  • d) The transmitter firmware updates will start automatically after disconnecting the transmitter from the computer. During the transmitter updating process, the system status LED will flash red and green. After the firmware update is complete, check the firmware version on a camera to ensure the firmware has been updated successfully.
2. If the update fails, follow the steps for troubleshooting.
  • a) Restart Osmo Pocket 3 and DJI Mimo.
  • b) Enable Wi-Fi and Bluetooth on the mobile device.
  • c) Connect Osmo Pocket 3 to DJI Mimo and try the update again.
  • Contact DJI Support if the update fails again.
Overview
  • Date: 2024.01.31
  • Firmware Version: v01.03.05.02
  • DJI Mimo App iOS: v1.11.6
  • DJI Mimo App Android: v1.11.4
  • DJI Mic 2 Transmitter Firmware Version: v04.03.08.31
What’s New
  • Added cancel recording function. Users can press and hold the Shutter/Record button to cancel during recording. The footage will not be stored after cancelling, saving storage space. (This function is not available in Timelapse, Motionlapse, and Webcam Mode.)
  • Added auto-power-off function for DJI Mic 2 Transmitter. When a transmitter is not connected to a device and is not recording independently for more than 15 minutes, the transmitter will automatically power off. When the transmitter is connected to the camera, tap settings > Wireless Mic > Auto Power Off to enable the function. (The firmware of transmitter should be v04.03.08.31.)
  • Optimized the recording gain for DJI Mic 2 transmitter and recording volume performance.
  • Added support for setting the audio channel in the Built-in Mic Audio Backup function. The channel parameters will be set the same as they are for the camera audio.
  • Optimized the controlling function for the 5D joystick in selfie mode. When taking a selfie, the panning direction of the camera is the same as the direction of movement of the 5D joystick.
  • Optimized the automatic recovery logic of the gimbal when exiting Transfer File/OTG Connection mode.
  • Optimized DJI Mic 2 transmitter performance and connection stability during livestreams.
Notes
  • Download firmware v04.02.01.13 or later from the official DJI website (https://www.dji.com/cn/osmo-pocket-3/downloads).
  • Make sure the transmitter is powered on. Connect the transmitter to a computer using the UCB-C cable.
  • Place the downloaded firmware update package .bin file under the root directory for the transmitter.
  • The transmitter firmware updates will start automatically after disconnecting the transmitter from the computer. During the transmitter updating process, the system status LED will flash red and green. After the firmware update is complete, check the firmware version on a camera to ensure the firmware has been updated successfully.
  • Restart Osmo Pocket 3 and DJI Mimo.
  • Enable Wi-Fi and Bluetooth on the mobile device.
  • Connect Osmo Pocket 3 to DJI Mimo and try the update again.
Overview
  • Date: 2023.11.29
  • Firmware Version: V 01.02.06.04
  • DJI Mimo App iOS: v1.11.3
  • DJI Mimo App Android: v1.11.2
  • Osmo Pocket 3 Battery Handle Firmware Version: v13.02.02.29
  • DJI Mic 2 Transmitter Firmware Version: v04.02.01.13
What's New
  • Added D-Log M (10 bit) and HLG (10 bit) mode when shooting in slow motion. This allows the user to capture scenes in greater detail, giving more flexibility in post-production. (Only available for 120fps.)
  • Added Built-in Mic Audio Backup function in Settings. When enabled, the camera will record audio through the built-in microphone and save it as a separate in .wav format audio file, which can be used to pick up environment sound when connected to a DJI Mic 2 transmitter or an external microphone. (This function is not available for low-light mode at 4K 30/25fps or slow motion at 4K 4x (120fps) D-Log M/HLG.)
  • Added support for recording 1080P 50/60fps video in webcam mode. When in webcam mode, swipe up to set the frame rate. Users can set the camera output frame rate to 25 or 30fps and change the PAL/NTSC format of the recorded video on the computer.
  • Added support for Selfie Flip in timelapse shooting mode.
  • Added auto-power-off function. When a transmitter is not connected to a device and is not recording independently for more than 15 minutes, the transmitter will automatically power off.
  • Optimized DJI Mic 2 transmitter performance and connection stability.
  • Added 2.35:1 Guides (reference lines) in Settings.
Notes
1. Connect the battery handle to the Osmo Pocket 3 to update the firmware. The battery handle will be automatically updated to the latest version of the firmware.
2. Connect the DJI Mic 2 transmitter to a computer to update the firmware. Follow the steps below to update:
3. If the update fails, follow the steps for troubleshooting.
Overview
  • Date: 2023.11.13
  • Firmware Version: v01.01.08.70
  • DJI Mimo App iOS: v1.11.2
What's New
Notes
  • If the update fails, follow the steps for troubleshooting.
Overview
  • Date: 2023.10.25
  • Firmware Version: 01.01.08.50
  • DJI Mimo App iOS: v1.11.0
  • DJI Mimo App Android: v1.11.0
What’s New
  • Added Image Adjustment. Sharpness and Noise Reduction level can be customized in Video, Slow Motion, and Hyperlapse modes (0 is default, -2 is lowest).
  • Added Screen Rotate & Capture. When enabled, shooting will be started as soon as the touchscreen has been rotated clockwise to power on the camera. After shooting, the camera will automatically power off if left idle for two seconds.
  • Added Low-Light shooting mode, helping improve image quality and reduce noise in low-light environments.
  • Optimized image quality and enhanced color performance.
  • Optimized the skin tone performance in multiple scenes.
  • Optimized accuracy and stability for auto-focus in multiple scenes.
Notes
2023-10-26
Tide
South Korea
Unusually well prepared launching firmware for a DJI.
2023-10-26
Fishycomics
Not asking a friend I got slammed by Hallmark007 for posting the truth, so let me ask DJI that will  tell me
Does the streen DIMM down exactly like the OA4 if so  I want to know  thanks
2023-10-27
DowntownRDB
Flight distance : ****
Very nice update.
2023-10-27
Canonian
Croatia
Is the font smaller now with the update?
It seems to me that before this update the text was bigger...
2023-10-27
dronethemoment
Flight distance : 9021293 ft
Still can’t set manual shutter speed greater than 1 second on Timelapse mode.
Pretty good update though.
2023-10-27
Dieter_Wilke
Just a new update (my 3rd since Thursday): V01.01.850
2023-10-28
PG73
DjI, will there be a firmware update soon to fix the issue where panning locks when the joystick is used in tilt-lock mode?
2023-10-29
hehe2
Please fix the overheating issue, I will probably return my OP3 if it's not fixed quickly enough.
2023-10-29
DJI Gamora
Canonian Posted at 10-27 09:19
Hi, Canonian. Thank you for reaching out. The font size did not change in the recent firmware update.
2023-10-30
DJI Gamora
dronethemoment Posted at 10-27 09:31
Hi, dronethemoment. Thank you for reaching out. This is normal, please check the specs as a reference:
Hope this helps. Thank you for your continued support.
2023-10-30
DJI Gamora
PG73 Posted at 10-29 04:33
Hi, PG73. Thank you for reaching out. May I confirm if you are unable to control the pan? Would you please provide us with a video showing the operation and issue? Please upload the file/s to Dropbox or Google Drive and provide us the shareable link via PM. Thank you for your cooperation and support.
2023-10-30
DJI Gamora
hehe2 Posted at 10-29 11:41
Hi, hehe2. Thank you for reaching out and we're sorry for the inconvenience. The Osmo Pocket 3 mainly dissipates heat around the gimbal, as the gimbal shell is made of metal. After prolonged recording, the temperature of the gimbal shell may exceed 50℃. Though the handle is made of PVC, the temperature increases the closer it is to the gimbal. When recording for a long time, it is recommended to attach the handle with 1/4″ thread and hold the device near the lower end of the handle. DO NOT cover or touch the heat dissipation area of Osmo Pocket 3 as it may become hot during use.
2023-10-30
PG73
DJI Gamora Posted at 10-30 07:22
Hi, I have been in contact with support today and they should be getting back to me, I've mentioned on other threads how to replicate the issue, anyone with a Pocket 3 should be able to replicate this so I think it's affecting all devices and requires a software update.
2023-10-30
Canonian
Croatia
DJI Gamora Posted at 10-30 03:30
Well DJI Gamora, I wouldn't say
It seems to me that someone did not pass that information on to support.
Cheers.
2023-10-30
Visual Air
Flight distance : 2710115 ft
Fishycomics Posted at 10-27 03:20
Just a suggestion. Maybe have a quick look at exactly what you wrote. Trying to understand what your asking or suggesting is super confusing.
2023-10-30
Fishycomics
Visual Air Posted at 10-30 18:00
thank you for that suggestion.
2023-10-31
DowntownRDB
Yes, I noticed the smaller font after the FW update also.
2023-10-31
djiuser_KTMtRksomnrc
Indonesia
Can not connect Mimo app or camera  on my Samsung a50s smartphone. Why not.
2023-10-31
DJI Tony
djiuser_KTMtRksomnrc Posted at 10-31 17:42
Hi there. Sorry about the inconvenience.  Are you getting an error? Can you elaborate on whats happening when trying to connect it?
2023-10-31
fans6512c8e0
Flight distance : 10115 ft
I'd like to suggest a couple improvements for next firmware release.
1. Adding a customizable smoothing option for the joystick movements. The current joystick movements (and zoom) are too harsh, they are very noticeable when used.
2. There is a slight focus breathing especially when using showcase mode. It would be cool to have an option for digital correction of the effect (like the Sony A74 does).
2023-11-4
StefanDjiMini2
Flight distance : 2004350 ft
Does the Pocket 3 have buzzing audio when an external mic is connected?
2023-11-5
daveypoo
Flight distance : 328176 ft
Soooo many jerky studders with this current gimbal firmware. At first I thought they were dropped frames, nope.....It happens when holding the gimbal steady with NO movement. Also, when holding steady, the gimbal has constant movement. We need a firmware as the video is impacted especially when panning no matter how slow you do it.  Lets gat a firmware update asap as I also see it in the many reviews online too! Thanks!
2023-11-5
fansbb981eaf
Die Pausenfunktion, die die Aufnahme kurzzeitig pausieren lässt, wäre mein größter Wunsch.
Der Pocket 2 hatte es ja auch.
2023-11-5
iagoab
Hello, with the new update this icon appears next to the one that indicates the remaining battery. what does it mean?
Thanks!
2023-11-5
DJI Tony
iagoab Posted at 11-5 14:55
Thanks!
[view_image]
Hello there. Thank you for reaching out. The icon indicates you are currently shooting horizontally. It will change if you switch the shooting mode to vertical. Have a great day ahead.
2023-11-5
DJI Gamora
fans6512c8e0 Posted at 11-4 13:46
Hi, fans6512c8e0. We'd like you to know that we appreciate your valuable suggestions. We will forward your concern to our related department. After the evaluation of the related department, significant suggestions or requests will be implemented via the firmware update, app update, etc. For any updates, please stay tuned to the latest news on our DJI official website at (www.dji.com) or by checking the Release Notes specific to your product. Thank you for your continued support.
2023-11-6
DJI Gamora
StefanDjiMini2 Posted at 11-5 06:37
Hi, StefanDjiMini2. Thank you for reaching out. The Pocket 3 should have that kind of sound as long as you use the recommended external microphones using the correct connection.
2023-11-6
DJI Gamora
daveypoo Posted at 11-5 06:58
Hi, daveypoo. Thank you for bringing this to our attention. Can you please provide us with a sample video to investigate this issue? Please upload the file/s to Dropbox or Google Drive and provide us the shareable link via PM. Thank you for your cooperation and support.
2023-11-6
DJI Gamora
fansbb981eaf Posted at 11-5 13:13
Hi, fansbb981eaf. I will take it as a suggestion of yours and will forward it to our designated team for attention. All significant suggestions will be implemented after the evaluation of our relevant team. For the latest updates please stay tuned to our DJI official website at ( www.dji.com ). Thank you.
2023-11-6
DJI Gamora
PG73 Posted at 10-30 07:31
Thank you for letting us know, PG73. Since you have been in contact with the support, please provide them with the needed details for them to investigate the issue. and should you need further assistance, please don't hesitate to reach us here at DJI Forum.
2023-11-6
DJI Gamora
Canonian Posted at 10-30 11:36
Hi, Canonian. Thank you for the reply. Our relevant team confirmed that the font size has not been changed. Due to visual errors and shooting angles, they will look a little different. Are there any changes that you want to make with the font size so that we can forward it to our relevant team? Are there any issues you're encountering with the font size? Please let us know.
2023-11-6
iagoab
DJI Tony Posted at 11-5 21:13
thanks for answering. definitely resolved. I couldn't find the drawing in the manual and I didn't understand why it appeared. I have already become familiar with those functions.
Now, the question is that the joystick of the pocket 3 can move the camera in 3 diagonals (apart from up down and left right.) but in the top-right diagonal the joystick is unable. is it something normal? Or could it be a mechanical problem with the joystick itself?
2023-11-6
DaveSp
Flight distance : 6562 ft
iagoab Posted at 11-6 07:28
Mine works across all diagonals though it can be difficult to get them.
2023-11-6
DJI Tony
Hi, iagoab. Will it be fine if you show us a video? I will get the related team to check on it. Thank you for your patience.
2023-11-7
daveypoo
Need an option to lock focus to infinity especially when walking.  Too much focus jumping.
2023-11-7
Psoon
Flight distance : 20617451 ft
I’ve change my joystick speed in ‘settings’ to 2 for Zoom and 1 for Gimbal, and that made a big difference.
2023-11-7
DJI Tony
daveypoo Posted at 11-7 07:11
We appreciate your valuable suggestions. We will forward your feedback to the related department for evaluation. Thank you for your great support.
2023-11-7
iagoab
DJI Tony Posted at 11-7 00:59
yes, I'm going to try to make a video
2023-11-7
iagoab
Thanks!
[view_image]
Regarding my old post, the screen lock icon, I have discovered that in normal video mode it saves my preference, but when I create a custom setting, horizontal lock always appears. I can change it, but it is not saved, as if it were in normal video mode.
2023-11-8
12345678Next >
