HDMI output possible?
12989 12 2023-10-29
nordheide21244
Flight distance : 241171 ft
Is there a way to stream directly to a hdmi monitor without mimo?
2023-10-29
DJI Gamora
Hi, nordheide21244. Thank you for reaching out. Osmo Pocket 3 does not have an HDMI port so it is not possible. Thank you for your kind understanding.
2023-10-29
FEBON
Taiwan
yes!
dji pocket 3 have two ouput
1. uvc output
2. rtmp output
you can turn uvc to hdmi . it is wire connection.
of course, when you use rtmp to hdmi idea, it will be wireless connection
https://youtu.be/irCQlb7SqSA?si=ERewI79a8kw9DDEj
2023-11-1
nordheide21244
FEBON Posted at 11-1 20:00
yes!
1. uvc output
Thx. Looked good!
2023-11-1
nordheide21244
yes!
1. uvc output
But it is not possible to convert the P3 USB-Output to HDMI - perhaps via adapter?
2023-11-1
fans84e741d3
Flight distance : 2392 ft
nordheide21244 Posted at 2023-11-1 23:57
I've tried cables, adapters and more with my Pocket 3 but no success with it.
2024-4-6
Cpt. Joe
Flight distance : 28389 ft
Austria
it is possible to use on your Smartphone the Mimo App. Some Smartphonse supports via USB-C an HDMI output (like some Samsung Smartphons), in this case, you will have an HDMI stream from your P3 ;-)
I use this config solution in combination with XR glasses (I hav an Viture One XR glass - works perfect).
2024-4-17
nordheide21244
Cpt. Joe Posted at 4-17 05:02
Thx. But i Need a clean putput with no time lack
2024-4-17
KWTMEDIA
Hey @dji we really need your help with the osmo pocket 3 uvc output I have been trying to use it with the osbot uvc To hdmi converter but the pocket 3 won’t send a video signal this way ( I have done the firmware’s update )
2024-6-25
FEBON
Taiwan
KWTMEDIA Posted at 6-25 10:27
1. vertical mode pocket 3 to hdmi
2 horizontal pocket 3 to hdmi
2024-8-26
KWTMEDIA
FEBON Posted at 8-26 16:02
[view_image]
[view_image]
How was this done can you share set up and connection cables
2024-12-30
monodistortion
KWTMEDIA Posted at 12-30 22:33
As Febon mentioned above, you can convert UVC to HDMI. UVC is a usb webcam connection that you would normally connect to a computer. This webcam connection can be converted to an HDMI video signal with a dedicated box. The Obsbot UVC to HDMI box should work or the box made by Febon should work. They all have quite a bit of latency so it's not really a perfect solution.
https://www.youtube.com/watch?v=gAn-anjJwXs
2024-12-31
IftiBashir
What's the latency like?
2024-12-31
