DJI Mini 3 Pro Quickshot / Mastershot Malfunction
1291 9 2023-10-30
ZZTOPGOLD
Flight distance : 4078 ft
Hi all,
I recently flew my Mini 3 Pro (with the RC and all firmware updated, no SD cards inserted) and I was encountering issues with "obstacle detection" when using Quickshots and Mastershots when in a large open field.
The issue is, the drone will start to do the Quickshot or Mastershot, then it would abort saying "obstacle detected" when there were no obstales near.
I would like to note that the Dronie and rocket modes worked, but not the circle or spiral. The mastershot did not work at all. I would also like to note that I kept trying until it started to get a little dark out. At this point, my drone prompted me that it was dark and some safety features were turned off, and then all quickshot and mastershot modes worked.
I am stumped because I have seen the modes work after some safety featues were auto turned off and some modes (dronie, and rocket) work while some of the other don't.
Any help and or advice would be appreciated!!
2023-10-30
DJI Wanda
Hello, there. Sorry for the inconvenience. Do you mean if you turned off the Obstacle Avoidance, all the modes can work properly?
2023-10-30
ZZTOPGOLD
I did not turn anything off myself. It started to get dark outside, so my controller gave me a notification that some safety features would not be available, then all the quick shot and master shots worked.
2023-10-31
DJI Wanda
ZZTOPGOLD Posted at 10-31 08:09
May we confirm the issue only occurs in the day? If so, when there is a point light source or strong light source (such as direct emitting or reflection from sunlight or fixed beam), the vision system may only check abnormal exposure and result in distance measurement failure. As such, the vision system may mistake for that the obstacle is huge and close.
2023-10-31
polygraph
Flight distance : 632405 ft
Czechia
I have the same problem, maybe it came with a software/firmware update. I could do mastershots before.
Any help would be nice!
2024-2-21
DJI Susan
polygraph Posted at 2-21 09:02
Hi there, sorry for any inconvenience caused. May I double-check if it only happens in MasterShots? And what is the current firmware version of your drone? Please try to refresh the latest firmware for the aircraft via DJI Assistant 2 and check again. Look forward to your reply.
2024-2-22
polygraph
DJI Susan Posted at 2-22 04:07
I noticed it as a problem in the master shots. It also appears, when I want to fly downwards. Then I have to switch to sports mode. Otherwise, it stops when going down or moves only very slow.
Aircraft Firmware: 1.00.0700
2024-2-24
polygraph Posted at 2-24 05:55
Hi there, may I ask if there is strong light emitting in the direction where a mistaken obstacle detection is reported? When there is a point light source or strong light source (such as direct emitting or reflection from sunlight or fixed beam), the vision system may only check abnormal exposure and result in distance measurement failure. As such, the vision system may mistake for that the obstacle is huge and close.
2024-2-25
polygraph
DJI Mindy Posted at 2-25 01:24
there is no strong light source - it even happens on cloudy weather, no sun, no direct light source hitting any sensor! Also no obstacles are around!
2024-2-25
polygraph Posted at 2-25 03:54
Does the aircraft report an obstacle when flying to a fixed direction? If so, could you please provide us with a sample video for further checking?
2024-2-27
