Proper focus with Lidar RS and RS3 Pro
2507 12 2023-11-3
hkarlsen_nor
Flight distance : 243445 ft
Norway
Hi all!
I am struggeling to get actual sharp images with the Lidar RS connected. I think I have every item on the latest firmware (focus/lidar/gimbal). I have tried different positions of the lidar, as close the the lens opening as possible, and inputing the offset in the gimbal. I have also calibrated the lens several times. Evertyhing is "working", with activetrack and everything showing in the gimbal monitor, but the focus beeing pulled is not correct.  I have not updated the lens motor recently, I did it once via the app on the Gimbal, but perhaps it should be updated on a computer? Any help?
Thanks!
2023-11-3
DJI Gamora
Hi, hkarlsen_nor. Thank you for reaching out. Can you please provide us a video of operation for further checking?
2023-11-4
hkarlsen_nor
Norway
DJI Gamora Posted at 11-4 06:42
Thanks for your reply. Please see attached video file. video test lidar rs
As it is clear from the video, focus is off by at least 10 cm+ around the 2 meter mark. I have done the calibration of this 50mm Sigma FF Cine 1.4 PL Mount lens several times. It not that strange, as there is only 2 marks required for the calibration. Why is this? No lens has the same turn of the barrel between 1-4 meters, and it will never work with so few marks. Why can't I add more marks to the calibration??
Thanks
2023-11-6
hkarlsen_nor
Norway
hkarlsen_nor Posted at 11-6 04:04
Heres a dropbox link as well
https://www.dropbox.com/scl/fi/voifi1y7eb3s7ya4efii5/video_test_lidar-rs.MOV?rlkey=vn1ylc2858tcjflm40n1y7qy2&dl=0
2023-11-6
DJI Gamora
hkarlsen_nor Posted at 11-6 04:09
Hi, hkarlsen_nor. Thank you for the link. We'll forward this to our relevant team for further checking. We'll let you know once we receive an update.
2023-11-10
hkarlsen_nor
Norway
Hi, hoping anyone else with a setup of manual cine lenses can chime in here. Are you able to get proper focus at wide open? I have the Sigma FF Cine Primes, and checking focus at f 1.5. After calibration, focus is only semi-tack sharp at the calibration distances 1m/4m. Anything in between is off by some cm. I can not understand how proper focus can be achieved with only 2 calibration points. When adjusting manually, the readout of the onscreen distance on the RC3 Pro (coming from Lidar RS) is correct, as I match the lens metering to that. But in AF, with only two calibration points, there is no way for the Lidar RS to know how the lens is mapped between 1-4 meters, right??
2023-11-22
djiuser_dXTvWgfrbiGH
Flight distance : 8596 ft
Russia
hkarlsen_nor Posted at 11-22 04:04
Hello, having the same problem, have you found the solution yet?
2023-12-3
hkarlsen_nor
Norway
djiuser_dXTvWgfrbiGH Posted at 12-3 07:47
Hi! Unfortunalety not. I am in email support with DJI, who is saying that product engineers are looking at it ( I made a new video). They are still saying they only need 1m and 4m calibration, which is very strange. Will keep you posted if I get anywhere.
2023-12-4
DJI Natalia
hkarlsen_nor Posted at 12-4 04:34
Hey there, l am also very concerning about  the issue you are encountering with, may l know if you could let me know the progress, l have not found any email related by searching your email address. thank you very much!
2023-12-6
ImagerieFilms
Same problem here. It seems it's happening with the sigma FF series. Any updates on dji side ?
Thanks !
2024-1-14
hkarlsen_nor
Norway
ImagerieFilms Posted at 1-14 11:59
Thanks !
They are eager to help via email, but as I am really stretched for time I have not had time to fully troubleshoot in a while. The main point for them was that the calibration has to be done with faces, not objects. But I believe I have done this as well and did not succeed. But will try again
2024-1-15
ImagerieFilms
hkarlsen_nor Posted at 1-15 00:51
It's not really face dependant. It worked perfectly with some lenses, and just not with the Sigma FF prime serie. Do you have a contact i can join at DJI to solve this ? Thanks !
2024-1-24
BCAC
Just seeing if there are any updates on this? A very simple way of being able to calibrate 4 total focus points per lens would fix this. Surely this is inbound in a future firmware update?
2-9 10:00
