Matrice 350 RTK Dual Payload
466 6 2023-11-5
nazar404.yahoo
Flight distance : 394291 ft
Just Purchased a Matrice 350 RTK and waiting to recieve it soon,  I also Purchase the H20 cmaera and the H20N .
Question is : Can you use both cameras at the same time and switch between cameras ?   H20 is a better day camera and bettter zoon and H20N is a better night camera .
Can't seem to find the answer
2023-11-5
DJI Wanda
Hello, there. Thank you for your support and interest. We will consult your questions with our engineers and get back to you here.
2023-11-6
DJI Wanda
Sorry for the late response. For dual gimbals mounted to the downward gimbal connectors, it does not support mounting two H20 series lenses at the same time.
If the aircraft has an upward gimbal connector, you can mount the H20 lens above, and the H20 N below.
2023-11-13
nazar404.yahoo
DJI Wanda Posted at 11-13 01:44
Wanda , to be clear on your answer ...  I can use both of my payloads H20 and H20N at the same time if I have a upper mounted gimbal and a lower mounted gimbal and switch between camera views ...
to be able to use the better zoom Len of the H20 while using the H2oN
is that correct?
2023-11-13
DJI Wanda
nazar404.yahoo Posted at 11-13 04:48
If you use the Single Gimbal payload combination, you can mount H20 on the Upward Gimbal and mount the H20 N on the Downward Gimbal.
2023-11-13
nazar404.yahoo
DJI Wanda Posted at 2023-11-13 05:20
next question is "  if you mount the zemuse p1 on the top and the image upside down and how do you invert the image ?
1-22 07:17
DJI Susan
nazar404.yahoo Posted at 1-22 07:17
Hi there, the Zenmuse P1 is not compatible with the upward gimbal, it can only be mounted on the downward gimbal. Please mount the Zenmuse P1 on the downward gimbal. Thank you for your understanding.
1-22 23:45
