New ronin m tilt not centered- tilting down
1323 3 2015-9-6
hawleaboy
New ronin m.  Gh4 perfectly balanced- footage looks great, but the tilt is -12 degrees (tilting down). The trim function can bring it to -8.  Tried calibration and center with the remote and still not centered.
The strange thing is that if I power up the remote and manually center the tilt to 0degrees and turn off the remote, the ronin holds the proper tilt in til I power cycle.
Is this a firmware bug in 1.3??
2015-9-6
DJI-Cathy
Click on "Default" after the update, enable pitch smoothtrack, and set the speed to 100, deadband to 0 to see,
If it happened after you did update the firmware, pls send your email to support@dji.com, let's downgrade the firmware to see if it helps
2015-9-8
atufilms
DJI-Cathy Posted at 2015-9-8 03:37
Click on "Default" after the update, enable pitch smoothtrack, and set the speed to 100, deadband to ...
I have the same problem and these recommendations didn't solve the issue.
2015-11-17
DJI-Cathy
atufilms@gmail. Posted at 2015-11-18 14:44
The latest version of Ronin-M is IMU1.4, please upgrade to see, make sure click on "Default" and do "Calibrate System" more than once
2015-11-23
