how to use geoid model for elevation CGG2013 in D-RTK2
606 11 2023-11-6
fifolong
Hi there,
I want to use D-RTK2 base station for my M350. Please kindly help on how to input the coordinates that I survey for the base location and produce the correct height in meters.  I use a geoid model for elevation CGG2013.
As I survey I simply want to put the elevation of base in MASL to match my datum otherwise if severely complicated everything.
2023-11-6
LV_Forestry
Flight distance : 4726654 ft
Latvia
Unfortunately it doesn't work like that.  The RTCM system uses the WGS84 datum.  The conversion must be carried out during data processing.
2023-11-7
fifolong
LV_Forestry Posted at 11-7 00:25
you mean with DJI TERRA?
2023-11-7
LV_Forestry
Latvia
fifolong Posted at 11-7 08:51
It is maybe possible with Terra yes. But i recommand professional grade software.
Photogrametry or LiDAR ?
2023-11-7
fifolong
LV_Forestry Posted at 11-7 08:57
both, actually.
2023-11-7
fifolong
any recommendation on software?
2023-11-7
LV_Forestry
Latvia
fifolong Posted at 11-7 08:58
I personaly use Metashape and GlobalMapper with DJI product.
Terrasolid is reputed as powerful for L1 data processing.
2023-11-7
fifolong
LV_Forestry Posted at 11-7 08:59
great thanks!
2023-11-7
DJI Thor
Flight distance : 13602 ft
Hi fifolong, for your inquiry, if you would like to perform a real-time RTK, you need to enter the WGS84 geodetic height of the D-RTK 2 base station location on the DJI Pilot 2. The input of data from other elevation systems is not supported.
2023-11-14
LV_Forestry
Latvia
DJI Thor Posted at 11-14 22:12
Hi DJI Thor, Could you please ban this user who is making duplicate answer. Post 9# this thread.
2023-11-14
fifolong
Thank you DJI Thor. well I hope DJI can make some improvement to include CGG2013 elevation.
2023-11-15
LV_Forestry
Latvia
fifolong Posted at 11-15 08:11
Read post Nr 2. This has nothing to do with DJI. The RTCM standard is made like this.
https://www.rtcm.org/publications
2023-11-15
