DJI MIC2 questions
2236 12 2023-11-7
UweE
Flight distance : 1016775 ft
I have 2 questions:
- is the Mic2 a mono mic or can it record stereo?
- the audio - to -video synch mode
  in the manual, it states, that there will be a 24-bit mono track been saved
even when I set the mic to -32-bit-float-  ?
2023-11-7
DJI Gamora
Hi, UweE. Thank you for reaching out. Let me confirm these with our relevant team. We'll let you know once we receive an update. Thank you.
2023-11-9
DJI Gamora
Hi, UweE. Thank you for patiently waiting. Here's the update from our relevant team:
1. Yes, the DJI Mic 2 Transmitter can record Stereo and Mono.
2. Yes, but kindly note that 32-bit is only available for DJI Mic 2 on-board recording.
Hope this helps.
2023-11-10
UweE
DJI Gamora Posted at 11-10 03:55
Thx DJI Gamora!
Regarding Point1:
is Stereo only possible when using TWO Mics?
I cannot change the setting from Mono to Stereo only for one mic.
2023-11-10
DJI-ytao
DJI R&D Squad
Flight distance : 1209413 ft
China
UweE Posted at 11-10 04:02
Thx DJI Gamora!
Regarding Point1:
yes, when connecting only one mic2, only mono.
when connecting to TWO mic2 , audio comes in with left and right channel separately in stereo:
2023-11-10
UweE
Okay, so my advise:
when you need stereo sound and it is not too windy, use the internal mics.
The sound is not that bad (the humming sound at the end is a very loud machine in the background)
2023-11-10
DJI Gamora
Thx DJI Gamora!
Regarding Point1:
Hello, there. Sorry for the late notice. Please note that at present, the DJI Mic 2 transmitters are not available for individual purchase. When you buy the Osmo Pocket 3 Creator combo, only one Mic 2 transmitter is provided. As a result, stereo recording mode is not supported. I hope this information helps.
2023-11-22
Mikedefieslife
Flight distance : 6627 ft
DJI Gamora Posted at 2023-11-10 03:55
And how do we actually change the setting of the transmitter from 24bit to 32bit float?
1-22 07:37
grempe
Mikedefieslife Posted at 1-22 07:37
Settings > Wireless Mic > 32-bit Float Recording [ON]
1-22 12:38
Mikedefieslife
grempe Posted at 1-22 12:38
I think you are missing the point. If you have the transmitter only, you cannot change any settings at all.
1-22 13:52
grempe
Mikedefieslife Posted at 1-22 13:52
Not sure I "missed the point". You never stated you might have ONLY a transmitter (no Mic 2 RX, no OP3).
If you are somehow in possession of only the transmitter, and nothing else, then I suppose you are right.
But if you have the TX and OP3 (the context of this post) or Mic 2 RX then my suggestion applies.
1-23 14:55
DJI Gamora
Hi, there. Thank you for the follow-up query. To access the setting via the DJI Pocket 3 Screen, from the main screen swipe down from up, select settings, select wireless mic, scroll down, and enable 32-bit float. I hope this information helps.
1-25 03:38
Gulnara Yusibova
Estonia
How to preventTX 1 recording TX 2 also in stereo mode? I wanna do podcast with 2 person. and when 1 person speaks to TX 1, and  second person also talks to TX 2, TX 1 records second person`s voice, too. and that sounds quiter but still it records and it heard. You have mentioned that it records on separate channels, but it is not true. Model is Dji MIC 2
4-7 09:28
