Can i use macbook pro charger of 67w for air 3 batteries?
4793 4 2023-11-10
djiuser_83KXaxUgs8f4
Argentina
I have a doubt if it is possible to charge the air3 batteries or hub with the charger of my MacBook Pro that is 67w and have pd protocol i think
2023-11-10
DAFlys
Yes,  the lower the wattage just means it will charge slower.
2023-11-11
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. DJI Air 3 uses the commonly available USB-C port for charging. You can directly use chargers with this type of port, such as those used for Android devices or Mac. Please rest assured that it will not damage your battery. You may refer to the information below.
1. When charging the battery with the battery mounted on the DJI Air 3 aircraft, if using a third-party charger, it is recommended to use a 65W fast charger that supports PD3.0 protocol.
2. When charging the battery using the DJI Air 3 battery charging hub, if using a third-party charger, it is recommended to use a 100W fast charger that supports PD3.0/PPS protocol.
2023-11-11
djiuser_uzqqCYigCSJe
Lebanon
Thought about using 140w one, but my go to is still the dji one
2023-11-12
Erik the Red
I have read this thread and note that it relates to the Air 3.  Does the same approach work with the original Mavic Air (model U11X)?
2024-2-29
