Mini 5 Pro wishlist...
1234Next >
33209 134 2023-11-11
DAFlys
Time to tell DJI what you'd like to see on a Mini 5.
for me:
  • A higher resolution camera with better dynamic range.
  • Vision Assist like they added to the Mavic 3 Pro.
  • Airsense
  • Better quality airframe with a longer life,   my legs got sloppy after 5500km and the replacement is coming up on that distance and is going the same way.
  • More supported charge cycles on the battery,  after 180 charges you get anonying nag on the screen at all times.
Feel free to add your suggestions below.
2023-11-11
Monkey007
Flight distance : 73775046 ft
Please elaborate, have you already done 5500km on the Mini4????
2023-11-11
Sean-bumble-bee
Flight distance : 15997 ft
Buy pivots and DIY replace them ????? How many opening and closing of the arms?
Or perhaps leave the arms in the flying position all the time, the latter would be a good way of checking whether or not it is wear that is causing the problem or something else.
I am fairly sure the front ones are 5 minutes work, can't remember if you have to open the shell to do the rear ones.
2023-11-11
Sam654
Flight distance : 132667 ft
Here are some, though I'll probably think of (remember) more. I have the M3P, so not sure if any of these are already in the 4.
360 Shperes
Shoot in portrait orientaion the capture the zenith properly.
Allow shooting with AEB and hi-res, saved as source photos.
Camera
Ability to adjust the stop-gap between brackets in AEB.
Adjustable apperture.
When recording in Log colour modes, an option to apply a LUT to the display for easier viewing.
Active Track
Track any subject, not just people and vehicles.
Follow RC location.
RTH
Option to toggle between classic RTH and an RT-RC mode. Useful when on the move, you don't need to keep updating home point all the time. I would certainly use this operating from a boat, but would be handy for any mode of transport.
Custom Routines
I know the 4 has waypoints where a mission can be pre-set. But I'm thinking of things that are not necessarily location specific. Think of Quick/Master Shots, it will carry out the same proceedure wherever you tell it to happen. So for example you could make a custom panorama shoot sequence, or design your own Master-Shots where it will carry out a set of pre-defined moves, or set up a shooting sequence for photogrammetry about a subject. Probably many other uses you can imagine.
And would be nice if you could set this up from the comfort of home on the computer.
That's it for now...
2023-11-11
Steph Jant
Flight distance : 152605 ft
Blimey, the M4P has only been out for a few weeks and already a post about a future drone that may never take to the skies.  There is just no pleasing some people!!
2023-11-11
Sam654
Steph Jant Posted at 11-11 08:37
I don't see any harm in discussing features we would like to see in future.
It may even lead DJI to consider adding features people actually want.
Some could potentially be added via updates to current models (though likely not older ones).
From my point of view, having got the M3P not so long ago, I don't see myself getting an M4P. Perhaps if/when the M5P arrives I will be due an upgrade.
2023-11-11
ryguyMN
Flight distance : 17480 ft
Wouldn't be surprised to see if they fit a one-inch sensor into the Mini 5 Pro.
2023-11-11
The Saint
Flight distance : 5902228 ft
The Mini 5 Pro is already in the hands of the DJI professionals and is likely flying around their offices today.  If not, they would be remiss because as an employee, you have to fly the drone that the public doesn't fly....that's a rule.
Do whatever you can to improve the drone without raising the cost or raising the weight.
2023-11-11
djiuser_d3Bi7bZgYQga
Optical camera vs digitalGoggle capability
2023-11-11
DJI Paladin
Flight distance : 318 ft
Hi there. DA. We appreciate you looking forward to our new products in the future. Please note that we don't have any information regarding the said product mentioned on the post but rest assured that this information will be forwarded to the designated team. Thank you for your valued support.
2023-11-11
DAFlys
ryguyMN Posted at 11-11 10:34
Id heard the Mini 4 Ultra might get the Pocket 3 camera for that.
2023-11-12
DAFlys
Monkey007 Posted at 11-11 03:20
No thats a Mini 3 but as far as I can tell it's the same frame.
2023-11-12
DAFlys
Sean-bumble-bee Posted at 11-11 04:31
As far as I know the entire shell has to come off to replace them,   Im probably better of paying DJI £30 to do it and get a new drone back.
2023-11-12
DAFlys
Probably because as a Mini 3 Pro owner the Mini 4 adds nothing that I want in a replacement and was quite the disappointment.    I could have had a free one from Argos but even at free its not worth it.
2023-11-12
Sean-bumble-bee
DAFlys Posted at 11-12 00:28
Assuming we are talking about your mini 3 pro ......
Sorry but
With regards to the rear pivots, looking at the pivots on ebay, the Mini 3 rear arm pivots are similar to the front arm pivots if the Mini 1/2 and M2P/Z. With those you remove the two screws clamping the pivot to the drone, position the arm at the tipping point between spring open and spring shut and pull the pivot out of the drone. Positioning the arm at the tipping point between spring open and spring shut take the stress off the arm and the pivot comes out and goes back in quite easily.
That said if the drone is still under warranty etc. yes I'd go with a DJI repair but it would be interesting to know where the problem lies.
2023-11-12
DAFlys
Sean-bumble-bee Posted at 11-12 04:49
Sorry but
https://www.youtube.com/watch?v=-WOToPMGiso
That is indeed easier thanI thought.  But Im struggling to find the parts from a reputable source that would be cheaper than what DJI charged me,   they wouldn't cover it under warranty but quoted £30 and sent me back a new drone,  which when youve got the airtime on the one I sent in that I have its nice to refresh the entire drone.
2023-11-12
Sean-bumble-bee
DAFlys Posted at 11-12 05:42
2023-11-12
Potato mini
Flight distance : 7275348 ft
Sam654 Posted at 11-11 07:37
360 Shperes
2023-11-12
Potato mini
360 Shperes
2023-11-12
Potato mini
360 Shperes
2023-11-12
Potato mini
360 Shperes
2023-11-12
Monkey007
DAFlys Posted at 11-12 00:29
Really? For me that O4 transmission alone is worth the upgrade, not to mention 360 obstacle avoidance and waypoints
2023-11-12
Bashy
Flight distance : 2354357 ft
Wait, what? If the drone is under 1 year old then it should be cover as its not a consumable, unless they state a max milage like they do with the battery cycles? Ive not seen a max milage mentioned. If not then they cant arbitrarily state its not covered under warranty, we have safe guards for that in the UK.
2023-11-12
Bashy
I would like to see a 1" sensor and variable aperture.
If i could afford to upgrade, i would have to the Mini 4 Pro as i like the additions that it has, especially the new on-screen additions, but the O4, waypoints and precision landing are up there too.
2023-11-12
DAFlys
Monkey007 Posted at 11-12 18:19
I have no issues with transmission.  I can easily outfly the battery if I wanted to now so more range is if no interest.   Most I fly with OA turned off as most of my flights are around dawn and dusk where it can get confused and stop the drone for no reason.     I’ve got waypoints on other drones and I’ve not used it.  And if I want to there’s a workaround on the mini 3 to do what I’d want to do with it anyway.
2023-11-12
DAFlys
Bashy Posted at 11-12 18:46
I forget the exact wording they used at the time but they basically accused me of either crashing it or being too rough.  And for £30 I wasn’t going to argue about it.  Not when they sent me a new drone.
2023-11-12
DAFlys
Bashy Posted at 11-12 18:50
1” would be nice.
The other features on the mini 4 dont appeal to me and I could have a free one from Argos.    But that all depends on what your using the drone for.  I regularly take off and land on a wall where precision landing wouldn't be precise enough and I suspect would just throw the area not suitable for landing message. But I can land there manually easily.   Waypoints I've got on other drones and I don't use it.  O4 I hear isn't much better in CE more than o3 was so that would still need an upgrade here.
2023-11-12
Monkey007
DAFlys Posted at 11-12 20:30
According to your interesting rationale you should be just as happy with a Mini2
2023-11-12
DAFlys
Monkey007 Posted at 11-12 20:43
Not really as the mini 2 camera in low light is terrible.   But if the camera and flight time matched the mini3 I would be.
2023-11-12
DAFlys
Dirty Bird Posted at 11-12 21:24
I have to say DJI is very reasonable on their repair rates.  I always tell people to just send the drone in & get it fixed properly.
I had a broken mini 2 gimbal that they replaced the drone for and it took them 3 units before they sent one that worked properly,  it was frustrating for me,  but they went out of he way to make things right and the price was very reasonable.
2023-11-12
Bashy
DAFlys Posted at 11-12 20:31
There is that i suppose, but that fact that they blanked over the distance travelled, its bound to become loosey loo. Does their testing even cover than many folds? i doubt it. As ya say, it was only £30 so i would have been happy paying that than to sit there arguing the point.
2023-11-13
Bashy
DAFlys Posted at 11-12 20:32
1” would be nice.
You know what folks kept saying for the range on the 3 Pro, so i would take any negatives on that with a pinch of salt. But then there is always FCC and i have seen that that is available
2023-11-13
Bashy
Agreed, the only time it becomes a major expense is when its the camera and/or damage to many parts
2023-11-13
DAFlys
Bashy Posted at 11-13 00:10
Thats exactly how I felt and I knew I was getting a new drone so took the easy life.
2023-11-13
DAFlys
Bashy Posted at 11-13 00:14
I damaged the camera, gimbal and an arm on the Mini 2,  totally my fault and it cost me £80 for a new drone.    I didnt think that was too bad.
2023-11-13
Bashy
DAFlys Posted at 11-13 00:42
If I remember right, the camera for the p4p was £300 or was it £600, for some reason I have it in my head that it was half the cost of the drone.
2023-11-13
DAFlys
Bashy Posted at 11-13 00:50
Im sure the mini series was a lot more sold than the phantom thus the costs came down a lot.
2023-11-13
TP-FPV
Flight distance : 1146821 ft
No doubt about that!
Same forum users posting the same nonsense, typical.
2023-11-13
Potato mini
TP-FPV Posted at 11-13 05:56
OR they aren't happy with  the mini 4 pro and are asking dji, instead of demanding the impossible, the things they would like to see on the mini 5 pro.
2023-11-14
Tech-Retard
Flight distance : 344 ft
As a newbie Mini 4 Pro owner I'm happy with what it has at this point.  Once I get more into flying and recording with it I'm sure I'll come up with a wish list of my own.
When it comes to the RC 2 controller that came with my Mini 4, there are several things I'd love to see changed or updated.
1.  Ability to make the controller the home point with a simple selecting of an icon.  This way I won't have to remember to update the home point each time I move to a different area.
2.  The ability to program either of the buttons on the back of the controller to act as an automatic home point updater.
3.  The ability to set the speed and smoothness of the zoom button on top of the controller.
4.  The ability to set the speed and the smoothness of the gimbal tilt button.
5.  The ability to select my SD card as the place where I want my screen recording to be stored.
I've mentioned all this stuff to DJI but, any replies I've gotten have been the generic, "We'll pass your suggestion on to those who deal with this kind of stuff over at DJY.
2023-11-14
1234Next >
