david.p.mann
Flight distance : 18669501 ft
Ibram,
To access and use Intelligent Navigation Modes, your I1 needs to be powered on, linked to the RC running the latest DJI Go app and in the air hovering. After the aircraft is in the air and hovering, moving the PAF switch to "F" mode will bring up the Intelligent Navigation menu in the middle of the camera screen with the following options: Home Lock, Course Lock, Follow Me, POI and Waypoints.
YES - your aircraft must be in the air before any of the Intelligent Navigation Modes will function. Further, Follow Me mode is not enabled (yet) for the Inspire 1 (only for Phantom 3). And to set Waypoints you must fly to each waypoint and then record it. You CAN save waypoint missions as favorites and replay them later. But there is no ability (at this time) to plan a waypoint mission offline by dropping pins on a map.
Forum member "Sploodge" has posted a detailed tutorial on the Phantom 3 forum on how to use all these modes. The same instruction apply to Inspire 1 (except Follow Me, which doesn't work with Inspire 1 in this release). |
