Pocket 3 - will this SD Card work?
5220 5 2023-11-17
Jennes74
Flight distance : 79764 ft
Switzerland
Since my supplier currently has the pocket 3 on Backorder, I already bought a (seemingly) suitable 512gb card.
However having second thoughts that the write speed will be sufficient enough.
Can anybody please weigh in on this?
Canvas Select Plus microSDXC Card 512GB
https://www.kingston.com/de/memory-cards/canvas-select-plus-microsd-card?capacity=512gb&adapter=sd%20adapter&packaging=single%20pack
2023-11-17
Labroides
Flight distance : 26781877 ft
It's much too big ... there's no real reason to have such a big card.
2023-11-17
TonyPHX
Flight distance : 12142077 ft
Kingston is good stuff. As long as it is authentic I don't think you'll have a problem.  As Labroides notes, it's on the large side.  We all want more more and more, but as storage density goes up, the chance for errors does too.  I like to stick to the 128's and 256's at most.  And never run out of storage, even when I don't dump the contents to computer regularly.
Good luck with the new Pocket 3!  Loving mine!
2023-11-17
Jennes74
Switzerland
TonyPHX Posted at 11-17 06:14
Got it. Thanks.
I do have a couple of 256‘s
And yes, agree on that card being on the larger side of things. However DJI states, that 512 should be supported.
I was more worried re the write speed.
Hopefully, my local supplier can replenish his stock asap, so I can finally get my hands on the pocket 3
2023-11-17
TonyPHX
Jennes74 Posted at 11-17 06:20
Got it. Thanks.
Enjoy!  The Pocket 3 has been really fun for me so far.  Used it on a commercial job recently, just for ground pics, but still fun, easy and just the right size.
2023-11-17
DJI Tony
Hi there. You can also check this list of recommended SD cards as they are tested and proven to work with the Pocket 3:
Have a great day ahead.
2023-11-17
