Land Avata with FPV Remote Controller 2
1590 5 2023-11-20
djiuser_pcjlWncY11OP
Flight distance : 8369 ft
I have seen videos online showing how to use the FPV controller 2 with Avata, but have seen nowhere the landing procedure with this remote. Any help would be greatly appreciated. Thanks
2023-11-20
Somer
Flight distance : 381821 ft
Poland
I usually change from manual mode to normal mode then i landing
2023-11-20
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. When using the DJI FPV Remote Controller V2, pull the throttle stick down to land the aircraft. Stop the motors after landing. Should you have other inquiries, feel free to contact us. Thank you for your valued support.
2023-11-20
Depp
Flight distance : 1868796 ft
Definitely land in N or S mode. Just fly where you want to land, stop and push down.
2023-11-20
djiuser_g7ae3cKl1GQW
Flight distance : 82753 ft
or don't even bother landing, just switch into N mode, take off goggles, fly it back to hover near you and just pick it from the air - flipping it over as you grab it stops the motors. It means you don't need a landing pad or somewhere safe/clean to land. I just take mine off from the back of my backpack and catch it instead of landing everytime.
2023-11-22
MaxwellKan
Flight distance : 1260174 ft
South Korea
In case of place like underground parking lot, changing to NORMAL or SPORTS mode might cause aircraft to drift & crash.
You have to Manual control aircraft to hover and slowy decend until nearly touch the ground then press motor stop button twice. About 20cm droppping will get impact warning after landing.
But CAREFULL if you hit the ground while landing with motor spin will make AVATA go out of control.
2023-11-22
