DJI Air 2s won't connect to remote controler
291 1 2023-11-30
imdronelover
Flight distance : 343766 ft
Serbia
Hi guys, I just wanted to let you know that I noted something "new". I said now because I didn't have that problem before.
So... if you have a problem that says "enable location services and app permissions to allow your mobile device to determine your location" popup all the time, even if you give all permissions to the app. In order to fix this problem, you need to make sure that Location is turned on, on your device phone/table.
2023-11-30
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. About the title, did you manage to fix the issue connecting your DJI Air 2s with your remote controller? If not, please make sure that both the aircraft and the remote controller use the latest firmware version. Please let us know. Thank you.
2023-11-30
