Night time hyoerlapse adruptly stops after a minute or so
404 5 2023-12-1
djiuser_UAPzMrwJbYVy
Flight distance : 3072448 ft
Flying the Mavic 3 completing a night time hyperlapse. The drone was set to course lock and on 2 separate occasions it stopped mid hyperlapse. No obstacles or input from the controller. Does anyone know if this is a known issue? Or what may have happened or if there is a fix
2023-12-1
JJB*
Flight distance : 12477300 ft
Hi,
best to get help/advice/explanation is to share your flightlog for this issue.
Use this link > https://www.phantomhelp.com/LogViewer/Upload/
Post the uploaded link on here.
cheers
JJB
2023-12-1
JJB* Posted at 12-1 07:57
Hi,
I attempted to do another one today and got a message that the micro sd card was too slow or write speeds weren't fast enough to complete operation. I'm kind of confused because this is the same micro sd card that I have used since I've had the drone since release dates. I have done countless hyper lapses in the past without a problem. Do you have any suggestions on a fix for this
2023-12-2
Mobilehomer
Flight distance : 18150351 ft
How full is it? The closer to capacity a card is, the slower it becomes. Either get a new card or back up and format this one.
2023-12-2
DJI Tony
Hi there. The SD card writing speed is related to the current number of files stored on the SD card and how it is used by the user. If the number of files is large, the writing speed will generally be slow. If you, for example, occasionally delete the files in the SD card, this will lead to more file system fragmentation on the SD card so the SD card write speed will slow down.
If the SD card writing speed is slow due to too much file fragmentation, try using a computer to format it. Have a nice day.
2023-12-5
djiuser_EEXtim8SFbZ6
Flight distance : 884301 ft
data jam on your sd card bro.  buy a few more rofl,
2023-12-5
