DJI Terra Exporting mission failed: File Write Error
340 8 2023-12-2
Budgebrewer
Trying to export a DJI Terra 3Dmission to a USB stick and obtain the above file write error.
Then get Please insert the last disk of Multi-Volume set and click OK to continue.
The USB is 128G with plenty of room.
What's going wrong?
2023-12-2
DJI Wanda
Hello, there. Sorry for the inconvenience. Could you please screenshot the error message you said for us?
2023-12-2
Budgebrewer
DJI Wanda Posted at 12-2 22:41
2023-12-2
Budgebrewer
And now the ZIp error keeps popping up during a subsequent (successful) mission.
2023-12-2
DJI Wanda
Thank you for the pictures. May we know what aircraft you are using?
2023-12-3
Budgebrewer
Mavic M3M. Import of RGB images only.
2023-12-3
DJI Wanda
Budgebrewer Posted at 12-3 12:46
Thank you. This error is about the disk. You can export to the computer local first.
2023-12-3
Budgebrewer
DJI Wanda Posted at 12-3 22:35
[SOLVED] : Thank you!
File size was ~34G. Terra zipped to hard drive OK.
Additional problem - file was too big for FAT system of 128G USB stick. Reformatted stick to NFTS.
Zip file now on stick, job done!
I wonder if Terra could have zipped to stick if it had been NFTS formatted in the first place?
2023-12-4
DJI Wanda
Budgebrewer Posted at 12-4 03:12
You can have a test.
Theoretically,  it can be supported.
However, we do not recommend that. The exporting time will be longer when the file is big and the USB stick might overheat.
2023-12-4
