Magnetic interference ..... a good read
518 12 2023-12-4
Sean-bumble-bee
Flight distance : 15997 ft
https://mavicpilots.com/threads/ ... n-and-errors.90792/
just come across this, another gem by sar104
2023-12-4
DAFlys
Didnt answer the one I get with the Mini3,   I fly from a wall quite regularly.  In daylight I never received a compass calibration message but if I fly there in the dark I get one every time.
2023-12-5
Sean-bumble-bee
DAFlys Posted at 12-5 01:39
Why not ask sar104 about the problem by posting a thread about it on the MavicPilots forum and perhaps make the .DAT available ?
2023-12-5
Labroides
Flight distance : 9991457 ft
It's a stupid message from DJI that makes no sense.
It's all about the dark, and has nothing at all to do with the compass.
I've posted about this before.
I've had it a couple of times in places I've flown in daylight.
No amount of moving the drone or even recalibrating the compass makes any difference.
But lighting the area around the drone with a bright light and the problem goes away.
2023-12-5
DAFlys
Labroides Posted at 12-5 03:23
I will try the light next time,   I fly pre dawn from this spot and it always complains,   but never is light.
2023-12-5
Labroides
The first time I ran into this, I couldn't make any sense of it.
It happened a few months later and I took some time to work on it.
I clicked on the Compass Calibration warning and it showed me more details, with a note about: Unable to take off in low light environment.
So I lit the area and it was no longer a problem.
It's got nothing at all to do with the compass despite what it said.
I have no idea why a low light environment matters, since the drone can fly perfectly will in the dark.
Just an example of DJI's very poor English language screen messages.
2023-12-5
Sean-bumble-bee
Labroides Posted at 12-5 03:34
With the mini 1 & 2 I get low light warnings almost EVERY time indoors.
If you get the compass error thing again and then 'advance' to your second screen capture, try touching the "Unable to Take Off" warning and see what you get.
The 'low light warning' is so routine for me I don't read the 'banners' and just press the required buttons but it may be that my "Unable to Take Off' banner takes me to the buttons/acceptances that I need to touch to allow motor start.
2023-12-5
Bashy
Flight distance : 2354357 ft
I dont know why it would do that, perhaps its a false positive stemming from the downward sensors, let DJI know and they should resolve it (in time lol), sounds like a code conflict to me.
As long as the drone indicator matches the drones direction then you have nothing to worry about and can either ignore it or, turn on the drone, in the air and away from the wall, then place it on the wall and see what it says then, if anything.
PS, FYI, Some walls can have reinforcing in them even if its just "ties".
2023-12-5
Bashy
Sorry, i should have looked at the following replies...
2023-12-5
DAFlys
Bashy Posted at 12-5 04:19
Yes. Some walls Ive flown from definitely contain metal,  but in this case I place the drone in almost the exact spot in the dark and get the error but go back a few hours later to fly again and in daylight no issue.
Ive since seen comments that the Mini 4 is also doing it.
2023-12-5
Bashy
DAFlys Posted at 12-5 04:53
Then deffo a conflict with the vision sensors, you know its safe to use it there so ignore it but i would mention it to DJI, the code needs a wee tweak...
2023-12-5
Labroides
Bashy Posted at 12-5 07:03
Knowing it's safe doesn't help.
You can't ignore it when it won't let you start the motors.
2023-12-5
Bashy
Labroides Posted at 12-5 12:50
You can't ignore it when it won't let you start the motors start the motors.
Is that a relatively new thing, not being able to start it?
Since I've been turning mine on in the air at around head height, I've not seen a compass error for a very long time, prob around 3 years, so when i say relatively new, i mean within the last 3 years lol.
EDIT: I just saw your post #8, i really should read all the replies 1st, that answers my question, sort of, as DaFlys is using the Mini 3 Pro, but i assume your method also applies here too?
2023-12-5
