DJI RC Remote Not Taking Pictures
522 7 2023-12-7
WesV
Flight distance : 1246834 ft
South Africa
Hi All...
I have the Air 2s and the DJI RC, recently noticed that it saves video on the SD card that's in the drone, but doesn't save any photos I take. The remote even makes the shutter sound when I press either the on screen button or the camera button, but doesn't save the photo.
I've put a SD card into the remote as well to test it and have factory reset the remote, but still no luck.
Has anyone had a similar problem and possible solution?
Thanks in advance
2023-12-7
jmb63
Flight distance : 7009439 ft
A few thoughts....Do you have it saving to the SD card and not the internal memory? Is the SD card formatted in the drone. If all else fails, try refreshing the firmware of the drone (and RC in this case) using the DJI assistant 2 program on a computer
2023-12-7
Sean-bumble-bee
Flight distance : 15997 ft
Are the breaks in the number sequence of the videos that would correspond to the missing photos ?
2023-12-7
WesV
South Africa
jmb63 Posted at 12-7 11:48
Yes... Saving to SD Card and SD card formatted in drone. Will have a look at firmware. It was just strange that it still saves the video perfect, but just not the photos. Will keep the thread updated. Thank you
2023-12-7
WesV
South Africa
Sean-bumble-bee Posted at 12-7 12:43
No, no break in the sequence. I usually sort my files so that I can see what item has which extension, but all mp4. Even formatting the card and taking a picture didn't save anything to the SD, also naturally then doesn't show up in the app library.
2023-12-7
jmb63
WesV Posted at 12-7 21:19
The first thing that DJI always suggests with these "weird" problems is a refresh of the firmware using the assistant program so definitely worth a shot...Yes, please let us know how you make out...
2023-12-8
Mobilehomer
Flight distance : 18150351 ft
These are probably the low resolution video previews that you are seeing. To get the full resolution, you need to download them from the drone to the controller. There are no photo previews saved to the remote.
2023-12-8
DJI Tony
Hi, Wesv. Please make sure all firmware is up to date.  And do the photo files not show in the aircraft album? if yes, please post a video showing the issue and I will forward it to the related team for further checking. We appreciate your patience.
2023-12-8
