Pilot 2 App & Linear Flight Mode
435 5 2023-12-8
mikes1
Flight distance : 1740699 ft
Trying out the new L2 using a Linear Flight Mode. This issue may not have anything to do with the L2. When trying to start the flight using the "blue button" it prompts me to "Select Flight Band To Execute". This is probably an easy fix but I haven't found it yet. Does anyone have the answer? Thanks in advance.
2023-12-8
LV_Forestry
Flight distance : 4726654 ft
Latvia
As it is written, you need to choose a flight band.  Even if there is only one!
2023-12-8
mikes1
LV_Forestry Posted at 12-8 09:14
Thanks, I understand I need to choose a flight band. The problem is I can't find where the setting is. I can change the flight band cutting distance. Is it on that page?
2023-12-8
LV_Forestry
Latvia
mikes1 Posted at 12-8 09:40
When it asks you to choose a band after pressing start, press it with your finger (the band).
2023-12-8
LV_Forestry
Latvia
https://youtu.be/8wodHRb9YLE?si=r4E_pb627oRCY7dW
Watch at 6min
2023-12-8
mikes1
LV_Forestry Posted at 12-8 09:49
Watch at 6min
Simple, yet hidden in plain view. Thanks
2023-12-8
