Johnnokomis
Flight distance : 13381447 ft
oberschneider.com Posted at 12-15 21:04
I was using a program called dcpTool (available in the MacOs AppStore) to read out the metadata from 3 DNGs of the 3 different cameras of my Mavic 3 Pro Cine, searching for the exact model name of each camera. The next step was to convert the original .dcp files of the Mavic 3 Pro from camera raw to XML files (again using dcpTool). Open the XML files and search for the camera module name at the very bottom of the file, and then just replace it with the model name of the M3 Pro Cine camera. Save the file, again changing the file name accordingly (though the correct file name might not really be relevant here, not sure about that), convert the XML to dcp using dcpTool, and copy the new file to the specified folder mentioned in my previous post.
I can do this for you, all I need is DNG files from every camera module of your M3E.
Yea I don't own the first Apple product so I don't think I could do that way myself. Here is a DNG file from the main M3E camera: M3E Main Camera DNG
Unfortunately for some unknown reason, DJI decided to make the 7x camera only shoot in .jpg and no raw capture. I really appreciate you doing this. |
