ghoonk
Flight distance : 394626 ft
United Arab Emirates
Unfortunately, like you, I've discovered that the iPad mini 3 WiFi does not have a proper GPS receiver built-in, nor will it be able to use the GPS signal from your smartphone even if you tether them. As such, only the 3G/LTE models will work with IOC.
It's a bummer, and there's not much DJI can do about that since the hardware doesn't exist on the iPad Mini WiFi models. On hindsight, I should have bought the LTE version instead.
I've had little to no luck with map caching - I do it before heading out for a flight, but when I get to the location, the data just isn't there, on my Xperia Z3, my iPhone 6+, and my iPad Mini 3 |
