GPS Problems?
1658 9 2014-12-10
stan
Hi I think I amimproving no crashes yet (famous last words) but I think I have aproblem.
I set up my FlamewheelF450 with Naza-M Lite on the ground and wait until the green LEDflashes at a nice even rate.
The I take off in GPSmode I then have to input some forward stick as the copter tries togo in reverse.
After about 5 mins thecopter, sometimes, stays steady but not all ways.
Is this normal or do Ihave a problem?
2014-12-10
Blade_Strike
Flight distance : 872694 ft
Do the drift happen in atti mode as well?
2014-12-10
jackson.zhong
Flight distance : 51243 ft
China
Try to  calibrate the compass before each flight.
2014-12-10
chrisgeigerphot
Flight distance : 13046529 ft
The first few seconds of flight the Naza is still figuring our what sensors are telling it what.  Put it on a level desk plug it in and calibrate the Naza.  Then take it out and fly it again.  Stay off the sticks other than throttle for a few seconds. The it should hold position. If you take off and hold one of the other three inputs it will tend to drift until you power off.
2014-12-10
stan
Blade_Strike Posted at 2014-12-10 23:59
When the wind drops I will check & let you know
2014-12-11
stan
jackson.zhong@d Posted at 2014-12-11 11:05
Done that & no Change
2014-12-11
stan
chrisgeigerphot Posted at 2014-12-11 14:18
The first few seconds of flight the Naza is still figuring our what sensors are telling it what.  Pu ...
When the wind drops ,Gales at the moment. I wil do what you say & try again
Let you know the results
2014-12-11
stan
Wind drops , Rains starts.
finely got a chance to try in atti mode  the answer is yes.
But I noted that when I change from GPS Mode to Atti mode  and back the copter seems to
Tilt back and forwords
2014-12-20
stan
Tilt back and forewards
Tried to leave the sticks alone and this as improved the situation but still a slight drift until I hover in one spot for some time
2014-12-20
DJI-Jackson
China
stan@graphic6.p Posted at 2014-12-20 20:00
But I noted ...
Show us a video how it looks like will be great helpful.
2014-12-23
