Which remote to use with DJI FPV air unit?
1710 5 2023-12-24
olegfly
I own a DJI FPV air unit system that includes the first version of the goggles and the remote controller. After buying Integra goggles and successfully pairing them with the FPV air unit, I've encountered an issue: the second-generation motion controller is incompatible with my unit, and the original controller no longer connects after a firmware update. Could you suggest an appropriate controller for my setup? Is buying a new unit necessary, or can I make it work with my current equipment? Cost isn't an issue for me, so I'm open to purchasing additional parts if needed.
2023-12-24
Depp
Flight distance : 1868796 ft
For the Vista/original Air Unit you need the latest firmware to work with the goggles 2/Integra. Downside: The old (black) controller doesn't work anymore. The Motion Controller (1&2) never worked on the Vista/Orginal Air Unit/O3. So you need to get the grey Controller 2. Or maybe switch to ExpressLRS and get the Radiomaster Boxer/Zorro or similar. If you go ahead on your fpv journey that might be the best route: RC and video link are "more separate" than having both from DJI. There have been reports of losing video and control at the same time. I'm perfectly happy with my Radiomaster Zorro and ELRS... The easier (though less flexible) route is getting the grey Controller 2...
2023-12-25
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. If you are using the DJI FPV System/Vista Air unit, you need to make sure that you are using the firmware v01.01.00.00 to connect the DJI Goggles Integra. The only remote controller that works on this setup is the DJI FPV Remote Controller 2. You may purchase the said remote controller using the link below. Hope this helps. We appreciate your valued support. Happy holidays!
https://store.dji.com/product/dj ... -nav&vid=102111
2023-12-25
olegfly
thank you both for the valuable information
2023-12-25
olegfly
So, I bound the goggles and the remote. How do I start the air unit drone? Also, is there a manual for the fpv controller 2 ? Thanks
1-2 16:17
olegfly
Bumping this. Sorry.
1-3 09:30
