FPV Remote 2 right stick error
255 3 2023-12-24
Jujakkol
Flight distance : 409541 ft
South Korea
DJI FPV REMOTE 2의 오른쪽 스틱에 오류가 있습니다.
스틱은 중앙에 있지만 신호는 왼쪽으로 약 60% 기울어져 있습니다. (축1/롤)
캘리브레이션을 해도 다르지 않습니다.
이 문제를 해결할 방법이 있나요?
아래 영상을 참고해주세요.
https://youtube.com/shorts/jsnd7jcRAFI?si=XnUxLXf6EmhdSenq
https://youtube.com/shorts/1ugn7fqmWZs?si=2VYUNd6V1ZPMwAIe
2023-12-24
DJI Thor
Flight distance : 13602 ft
Hope you are doing well. Thank you for your inquiry. Sorry that currently we can only provide English service here.Please no worries, we have forwarded to video to our engineer team and check on it. We will keep you update soon.
2023-12-25
Jujakkol
South Korea
Rewrite in English.
There is an error with the right stick of DJI FPV REMOTE 2.
The stick is centered, but the signal is tilted about 60% to the left. (axis 1/roll)
Calibration does not solve the problem.
Is there any way to fix this?
-> I contacted the DJI service team today and decided to receive after-sales service.
2023-12-25
DJI Thor
Jujakkol Posted at 12-25 03:05
Rewrite in English.
Hi there, after checking with our engineer team, we found there might be a deviation on the simulator.
Before you send back, you could troubleshoot as the following.
Firstly, may I know which simulator you used? We would like to double-check the compatibility.
At the same time, please also try the actual flight with the remote control stick. If there is no problem with it, then it is basically an issue with the compatibility or settings of the remote control and simulator. Please try and keep us update, thanks.
2023-12-25
