Yaros1
Flight distance : 19981112 ft
Hi,
I have owned and hand landed the Air 2 and Air 2S, no issues there.
But now I bought the Air 3 and find it ridiculously hard to hand catch, not because of the size of the drone or anything, because it just refuses to go down in my hand.
And yes, I am aware that you can disable the bottom sensors with the new firmware update, but that is very tedious to do every time you want to hand catch the drone.
It seems to do some trickery to know where you're landing and avoids landing on uneven surfaces, which is a good safety feature, but it makes it dangerous to land in certain situations.
Would be really great if it would let you land if you hold the stick down for long enough.
For example, on the Air 2 and Air 2S you can land while holding your hand under the drone and holding the left stick down for 3 seconds, it slowly will descent into your hand.
However, that is not the case with the Air 3. It pops a message on the screen that it is not safe to land in the current area and to fly to even ground to land there. There is a way to let it land in your hand, by first initiating landing using the DJI Fly app's menu, and then quickly put your hand below it, while holding the stick down, but it's very far from a perfect solution.
I know that most will argue that it is inherently unsafe to hand catch such a big drone, but that doesn't worry me too much, I also hand launch and land my FPV drone.
Sometimes it is just not possible to land on even ground, and the drone should let you land anywhere if you tell it for long enough. |
