Phantom 3 Wifi password on RC doesn't reset on RC Help
339 1 2023-12-28
Dan Alexander Wilson
The issue I am having is with the DJI go internet password.Please before you send the video link, the toggle reset, the manual drawings and so on none of it works.
I have tried resetting it and using the factory setting 12341234.
There is a difference with my RC.
When I follow the reset wifi connection on the RC it doesn't flash red, it stays a solid green.
I know the remote and the aircraft are connected as the camera works from the remote toggles, but the aircraft doesn't.
My Phantom 3 is flashing yellow at the moment, and the link light is green.
I have a phantom 3 standard and I would love to get it in the sky but it just won't correctly connect.
I know I am close it's just a password away, unless it's a RC issue?
2023-12-28
DJI Wanda
Hello, there.  Please make sure you reset Wi-Fi in a right method: Move the gimbal tilt dial to the top and quickly move the S2 Switch.
You can check P.26 for more information:
https://dl.djicdn.com/downloads/ ... _Manual_v1.4_en.pdf
You can also record a video about the resetting for us.
2023-12-28
