Has anyone tried the latest FW update 01.03.1000 released 27th Dec for the RC Controller? If so, I am curious, have you noticed anything different with options or settings? Myself I haven't tried it yet, I am still running the 14 Nov release 01.03.0700
The latest for the mini 3 pro is 01.00.0700 released 26 Sep. No specific details from DJI other than "fixes known issues"
To answer your question "is it necessary ....." is next to impossible to determine when no specifics are given with their FW updates. Myself I have the latest FW on the drone.
Seems like I cannot choose H.264 as a coding option anymore.
I wonder if that is what they're referring to when they talk about "fixing known issues"...
Outpost6E Posted at 12-30 00:47
I just carried out the latest RC controller FW update 01.03.1000 and so far nil discrepancies noted; H264 on my end is still displayed as an option (myself I utilize H265 for optimum video compression).
Rej, thank you for checking.
It turned out that I had to refresh the firmware twice with DJI assistant 2 for H.264 to reappear.
At first it vanished after picking the cinelike mode.
djiuser_elY2LBq36hDD Posted at 2023-12-29 13:23
is it necessary to update to the latest firmware the drone too (mini 3 pro with 01.00.0600 firmware?
If you are in the United States and bound by FAA part 107 regulations then technically keeping firmware up to date would be part of your maintenance procedure.
Hello, there. Thank you for reaching out. Yes, the firmware for the DJI RC will be applied when the DJI Mavic 3 Pro is in use. I hope this information helps. Thank you for your support.
