Gimbal jerks & twitches while flying
495 5 2023-12-29
volaredrone
Flight distance : 3564685 ft
I've had two different Mavic 3 Pros now and this has happened on both drones - so not an isolated issue.
While flying (and sometimes filming), the gimbal / camera will tweak out and jerk to the side. This isn't every flight, but probably around 5% of flights it happens?
When I'm filming straight down and flying (backwards I think) the gimbal will sometimes even revert to the 90 degree position.
I'm assuming this has something to do with the gimbal reaching its max range, but in each of these cases I'm usually in Cine mode, low wind, and flying very gently / drone isn't tilted strongly.
I was able to capture this example the other day:
https://drive.google.com/file/d/1QsozJsBf2AG2MKKLXMW2e8tLwABIlBbZ/view?usp=sharing
As you can see, I'm flying very slowly here. No reason the gimbal should be getting stressed.
Any fixes for this?
2023-12-29
Suren
Flight distance : 13498560 ft
New Zealand
Just to ask the obvious but have you done a Gimbal Calibration to see if that fixes the issue?
2023-12-29
DJI Gamora
Hi, there. We're sorry for the inconvenience. May I confirm if you tried to perform the gimbal calibration?
2023-12-30
volaredrone
Hello, I have not tried that yet. I will do that and see if that resolves the issue.
Thanks
1-3 08:58
DJI Gamora
volaredrone Posted at 1-3 08:58
Thanks
Thank you for responding. Please feel free to keep us posted about the latest progress.
1-6 01:15
NYC
Flight distance : 20169501 ft
Thanks
That should resolve it. I've had the same problem. Do the cali
1-14 02:56
