Osmo Pocket 3 Gimbal Protection Error
21597 25 2023-12-29
Earth Monkey
My Osmo Pocket 3 is brand new, i've used it a few times around the house thats it.... yet out of no where it just comes up with "Gimbal Protection" with the recenter button doing nothing. Swiping left and right does nothing, record button and joystick does nothing, attaching it to dji mimo app does nothing. I now have a $1000 chunk of worthless tech in my house that is brand new.
Also I have the newest firmware which I updated about 2 weeks ago.
2023-12-29
DJI Tony
Hi there. Sorry about the trouble. Can you please try the steps below?
1. Please verify if the product is undergoing continuous power cycles (the gimbal is powered on and off continuously within 3 seconds or powered on and off repeatedly within a short period).
( Due to the large thrust required for locking and unlocking the gimbal, continuous output in a short period may result in the inability to unlock or lock the gimbal tightly. It is recommended not to frequently power on or off the device.)
2. Please confirm if the device has been stored below 0 degrees or if the current ambient temperature is below 0 degrees.
( When the ambient temperature drops below 0℃ or when the product is brought indoors from
a 0℃ environment, the gimbal axis lock may become difficult to release. It is recommended to use the product within the operating temperature range to avoid such situations.)
3. Power off the device, and check if there are any foreign objects (e.g. sand) between the axis arms. If yes, clean off the objects and restart the gimbal.
Have a nice day.
2023-12-30
Earth Monkey
DJI Tony Posted at 12-30 00:19
After going to bed and waking up it work again but I need to know why it does this? I can't be out in the field and have the camera stop working.
The device is stored indoor at 17 degrees C.
No obstructions, no dirt or anything.
If this problem continues will I get a new pocket 3 free of charge?
2023-12-30
DJI Tony
Earth Monkey Posted at 12-30 10:26
Hi, Earth Monkey. We understand the inconvenience. If the issue continues, we suggest sending it back for inspection and to fix it. The warranty can be applied depending on the assessment's outcome, including your unit's warranty period. We appreciate your patience.
2023-12-31
KellerCommunications
I encountered the same error, followed the instructions above and could not see any debris or physical damage. I tried to calibrate the gimbal but that failed. Finally in frustration I gently rotated the gimbal in a full cycle and suddenly the error resolved and the camera is back to working normally.
It is clear this mode is in response to either an impact, forced rotation, or debris. It's frustrating that there are no clear steps to resolution from that error message.
If anyone else has this problem try my troubleshooting method before you return your camera.
2024-3-29
Solveira
Flight distance : 1416224 ft
Portugal
Same problem here, a new one, open the box, switch on and Gimball Protection error!
2024-4-22
djiuser_fgsGYOKd9Bmu
Malaysia
Solveira Posted at 4-22 13:54
Here are the steps you can follow to address the issue with the DJI device's gimbal:
1.Start by clicking on the camera view screen. This action should prompt the gimbal to automatically return to its normal working state.
2.If the gimbal issue persists, power off the gimbal and carefully inspect whether there are any foreign objects, such as sand or stones, lodged between the axis arms. If you find any foreign objects, clean them out and then restart the gimbal.
3.If the problem continues even after performing the above steps, it is recommended to advise the customer to return their device for further testing and examination.
Please note that the DJI device enters the "Gimbal protected" state when it experiences external force. It's worth mentioning that if video recording is in progress, it will not be interrupted by the gimbal issue.
2024-4-22
DJI Tony
Hi there. Have you already tried the procedures above in reply 2#? You can also try tapping "Recenter" or manually rotate the gimbal to unlock it from the stored position. If this issue occurs every time you power it on without being influenced by low temperatures and if it feels noticeably stuck and the gimbal is unable to rotate we suggest sending back the unit. Please keep us posted. Thank you.
2024-4-22
fans817ba250
Now I have the same problem. I’m at Disneyland and so mad that this happened right now. I was recording a parade and when I shut off I got the gimbal protection error and now it won’t work. I reset all my settings to factory default and same thing. This is very upsetting especially for the amount I paid. I’ve tried the steps above, so I have no choice but to put it away. Ruined my day at Disneyland!!
2024-5-17
DJI Tony
fans817ba250 Posted at 5-17 18:43
Hi there. We suggest sending the unit back to DJI for further checking. You can submit a repair request here (https://www.dji.com/global/support). The warranty can be applied depending on the assessment's outcome, including your unit's warranty period. Please feel free to keep us posted if you have further concerns. Have a nice day
2024-5-17
fans421bac2a
KellerCommunications Posted at 3-29 09:13
Thank you, the method of gently rotating the gimbal in a full cycle resolved my issue
2024-9-27
Renata Rath
I gently rotated the base of the gimbal with my hands and it resolved itself.
2024-11-22
djiuser_u8VEntN8Cv5z
Switzerland
Aynı hatayı alıyorum ne yaptıysam olmadı bunun bir çözümü yok mu garantisi mevcut geri mi göndermeliyim
2024-12-24
labs023
Flight distance : 62421 ft
New Zealand
Was your OP3 ON or OFF when you rotate the base?
2024-12-24
DJI Diana
Flight distance : 2408 ft
djiuser_u8VEntN8Cv5z Posted at 12-24 09:52
Hi there,
thank you for reaching out.
We apologize for the inconvenience. If you have followed the suggestion made by DJI Tony in reply #2 and the issue persists, you may send the product back for further inspection. This matter will be addressed appropriately by our team.
Feel free to contact us should you have any questions.
2024-12-24
djiuser_QrxsepHYCb3Z
Norway
I have same problem, just got it for a week. Tried everything you suggested here but still nothing happend. Im charging it now and will try it again later. Hopefully it will work.
1-2 05:36
Charlie Au Young
Brand new open from the box and I am stuck on this
1-17 21:45
DJI Natalia
djiuser_QrxsepHYCb3Z Posted at 1-2 05:36
Hi there! We would like to apologize for any inconvenience you may have experienced. We understand that you are currently facing an issue with 'Gimbal Protection.' Worry not, you may follow the troubleshooting guidelines below:
1. Firstly, please ensure that the firmware version is the latest version. If not, please update it first via the DJI Mimo app.
2. If the gimbal protection mode cannot be exited, and there is no response following a tap on the screen, press and hold the record button for 10 seconds to forcibly power off the device, and then power on the device. Alternatively, update the firmware via the DJI Mimo app.
3. Please verify if the product is undergoing continuous power cycles (the gimbal is powered on and off continuously within 3 seconds or powered on and off repeatedly within a short period of time).
**Due to the large thrust required for locking and unlocking the gimbal, continuous output in a short period of time may result in the inability to unlock or lock the gimbal tightly. It is recommended not to frequently power on or off the device.
4. Please confirm if the device has been stored below 0 degrees or if the current ambient temperature is below 0 degrees.
**When the ambient temperature drops below 0℃ or when the product is brought indoors from
5. After entering OTG mode, it will automatically switch to "gimbal protection" status. When exiting OTG mode, to prevent it from automatically starting while lying flat, you need to manually click to restore after unplugging the cable.
6. Power off the device, and check if there are any foreign objects (e.g. sand) between the axis arms. If yes, clean off the objects and restart the gimbal.
Note: In OTG connection mode, gimbal protection is enabled automatically to make it more convenient to place the gimbal. After exiting the gimbal protection mode, a manual operation is required for restoration. This is not an exception.
If the issue persists, please do let us know for further assistance. Thank you.
1-17 22:14
DJI Natalia
Charlie Au Young Posted at 1-17 21:45
1-17 22:14
VIRNA
Philippines
Same thing happen to me, good thing after I manually rotate all moving parts of the camera, it works.
1-23 07:55
DJI Gamora
VIRNA Posted at 1-23 07:55
Hi there, thank you for the update and we're glad to hear that the issue has been resolved. DO not hesitate to contact us back if there's any further inquiry.
Thank you!
1-24 02:29
user58679
Hi, this has now happened to me, and I bought this 2 weeks ago can you clarify when you manually rotated the moving parts did you do this while it was charging or when it was turned off?
1-27 14:51
fanse2d18a9d
Same here, Osmo Pocket 3 displaying “Gimbal Protection” messages same day I got it. So frustrating, it’s happening like 4 times a day. I have to spend like 10 minutes of trial and error just to get it going again. Sometimes it vibrates violently just stuck… $800 CAD I spent on this smh
2-2 15:57
DJI Natalia
fanse2d18a9d Posted at 2-2 15:57
Hi there, thank you for reaching out. Kindly click  the camera view screen. Then, the gimbal will automatically return to the normal working state. Power off the gimbal and check whether there is a foreign object (such as sand or a stone) between axis arms. If there is, clean them and restart the gimbal. If the issue persists after the above solutions have been tried, it's advisable to return the device for testing.
Keep us posted on the outcome. Thank you for your kind understanding.
2-3 04:23
Tons
I just purchased one today, aside from not recentering properly after a panning shot, I am now getting gimbal protection going on. This is really frustrating as I never had this in my DJI Pocket 2.
2-3 12:37
DJI Gamora
Tons Posted at 2-3 12:37
Hi there, thank you for reaching out. If the gimbal is still in the stored protection and cannot be unlocked due to a "Gimbal Protection" warning is shown, please follow the steps below.
3. Please verify if the product is undergoing continuous power cycles (the gimbal is powered on and off continuously within 3 seconds or powering on and off repeatedly within a short period of time).
* Due to the large thrust required for locking and unlocking the gimbal, continuous output in a short period of time may result in the inability to unlock or lock the gimbal tightly. It is recommended not to frequently power on or off the device.
* When the ambient temperature drops below 0℃ or when the product is brought indoors from
Please keep us updated on the progress.
2-5 12:33
