no option to deactivate "FOV-Controlled Gimbal Speed"
461 1 2023-12-30
fansba3b7009
Flight distance : 314908 ft
Austria
am I missing something or is the option to deactivate "FOV-Controlled Gimbal Speed" no possible on the I3?
this is a key feature for me on the I2, I need the same speed on all different lenses - from wide to tele
otherwise I am not able to operate the camera presice and fast enough
is this an still an option on the I3? on the the I2 it was in the advanced settings in the gimabl tab
thanks for help
2023-12-30
fansba3b7009
Austria
major bug in the firmware , the "FOV-Controlled Gimbal Speed" also effects the yaw speed of the drone!!!!!!  if you fly a 50mm it spins so slow on yaw that you cant make tight turns....this is really dangerous !!
this has to be switched off, at least by the user and should never mix into the drone flying settings
1-8 06:53
