Capturing 4K video
345 6 2023-12-31
Thopter
Hello, I am trying to find out if there is a consensus regarding the brand & specs of Micro SD best suited for Mavic 2 pro 4K recording. Also would it be advisable to use a lesser capacity card such as 64 or 32Gb?  The information available on this forum is incredible it's become the goto resource for me & others I know, many thanks for the help.   Paul R.
2023-12-31
yogi053
Flight distance : 26104915 ft
I use 64gb Sandisk cards in my M2P and have had no problems whatsoever. I download my cards  after flying to my PC and then format them again ready for next flights. Just make sure the cards areon Dji compatible list.
2023-12-31
Johnnokomis
Flight distance : 13381447 ft
For video you want to look at the V## label on the card. The Mavic 2 Pro records as a max bitrate of 12.5 Mb/s so you'll want a V30 or higher card. Get a good name brand card, they've come down so much in price that there's no reason to cheap out on them. Memory-Card-Video-Speed-Classes.png
2023-12-31
DAFlys
I use 256gb Sandisk Pro Extreme cards in my M2P.  They are rock solid cards.
1-1 01:02
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. Mavic 2 can support Micro SD with a capacity of up to 128 GB and R/W speed up to UHS-I Speed Grade 3. You may check for the list of recommended SD cards below. Hope this helps.
32G
Sandisk V30
Sandisk Extreme V30 Pro
64G
Sandisk Extreme Pro V30
128G
Sandisk Extreme V30
Kingston Canvas Go!
Kingston Canvas React
1-1 01:42
Thopter
yogi053 Posted at 2023-12-31 16:49
Thank you.
1-1 19:15
Thopter
Johnnokomis Posted at 2023-12-31 17:18
For video you want to look at the V## label on the card. The Mavic 2 Pro records as a max bitrate of 12.5 Mb/s so you'll want a V30 or higher card. Get a good name brand card, they've come down so much in price that there's no reason to cheap out on them. [view_image]
Thanks for that.
1-1 19:16
